Ok guys. I'm new here and don't think Ive posted before but I've done my research. Also, first Euro car woo!
I bought this B6 1.8t for $900 with a few problems of course. I had a fun time replacing the CV axle and a few other projects.
Its got roughly 75k on it (speedo and tach doesn't work, still waiting on vcds scan) but I decided to dive in to my first timing
job before I end up with some hefty replacement costs. I made it through well enough with the install and turned it over to verify
the marks were correct. As it turns out, the mark I made on the crank line up, so do the cam marks. But the crank pulley set to its
mark shows the cams are off maybe 2 teeth or roughly 20 degrees. I don't hear metal to metal and I'm assuming the resistance
would be worse turning the crank if I'm bending valves. it does return on its own but I would guess that's the cam springs maybe?
So before I reassemble this and maybe something goes very wrong I would like to verify timing. The numerous posts and videos
I went through tell you to verify but don't go into it. How can I verify everything in spot on? and if I didn't nail it (assuming i dont
need a new head) how do I reset the pin for the tensioner so I can set it? I'm still pretty new to doing timing but I've had a fair
bit of literature. Any help would be greatly appreciated and I will provide as good of details as I can if needed. Thanks
