Results 1 to 10 of 10
    Apr 03 2016
    Lakeland Florida
    98 AEB 1.8t mods
    Just got a 98 a4 1.8t quattro what the best support mods to do that will work with stock software??? Also I am gonna install a clutch and flywheel was researching a vr6 clutch and g60 flywheel..I need some LUK part numbers
    Dec 10 2013
    Borden, Ontario, Canada
    1. Google. Use it.
    2. Why the hell are you using VR6 stuff besides a throttle body?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Apr 03 2016
    Lakeland Florida
    I did use Google thats where I was reading about vr6/g60 flywheel on 1.8t just needed to know if that combo works on a4
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    But why
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    You sure that fits an A4? Never heard anyone using one, and the only thread I saw says it's for mk's.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Rpnj82 View Post
    They use a 228mm clutch anyways. I see zero benefit to using that flywheel even if it is possible.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    why do you want to change the clutch? is the clutch slipping? if not, dont touch it until it starts slipping. when it does go, you dont want g60 parts, you want the 240mm upgrade if you are going with a whole new kit including the flywheel.
    since you just got the car, you should make sure it is 100% mechanically sound before you do ANY mods.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by GrapeBandit View Post
    ^^this. Then, get a boost gauge and fix all those problems.
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Quote Originally Posted by Rodgman15 View Post
    ^This
    Apr 03 2016
    Lakeland Florida
    I got the car for $600...compression 165psi all 4......needed Ignition module because of cylinder 2 misfire, the l/f axle was hanging of the axle cup the car wouldn't move...so the kid thought it needed a clutch, the interior is worn out.I replaced all crankcase hoses....The trans is hard to shift through the gears even with the engine off with it it running it does shift but it's notchy pedal feels good but I think it has release problem
