Results 1 to 14 of 14
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Boost leak or????
    Anyone have any idea on what to check on why my SC is boosting more than normal?
    It's been creeping up the past month or two and hit the high score of 20psi and a yellow EPC light followed by limp mode. Normally it's around 18 or so, originally 17ish.
    Car has been pulling like crazy though.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Low DA, Cold temperatures???
    I've seen my boost on the P3 (requested not actual as i'm tapped into the OBD2) but it would vary from mid ~15.5 to sometimes high ~16.7 however I dont remember ever seeing anything above 17... depending on the conditions, sometimes the car just rips though.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Dec 19 2010
    North CA
    I'm tapped, so I'm not using the requested boost through odbII.
    What's more concerning is that my car goes into limp... I like the extra speed haha.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    You have to recalibrate it.. Should be back to normal then.
    Idk about limp mode though
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Nov 20 2014
    New York
    What mods? Shit I want 20 psi but without limp mode lol
    Dec 19 2010
    North CA
    Quote Originally Posted by DGVR6 View Post
    Nope, even after calibration.... I got a higher score now 20.1
    Dec 19 2010
    North CA
    APR Stage 2
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Has this corresponded with ambient temps getting warmer?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Dec 19 2010
    North CA
    Boost leak or????
    Not sure if related. It's 59 degrees right now. Went into EPC when it hit 20.1
    For fun I put it to stock mode and I get a 10.6 high.
    Also, any idea what I can log to see what's going on?
    I pulled faults earlier, said cylinder shutdown and misfire on cylinder 3. I assume it's misfiring due to the shutdown (limp mode)
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Interested in seeing what you find
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Well its one of 2 things. If your in stock mode and the boost value is correct for stock and it has an issue when in stage 2. Then you have a problem with software. But if you had the apr dealer reflash it and the problem is still there then I would thing you might have a bypass valve that's starting to stick. I am not sure how that's monitored. If its monitored just like a TB or not. You should be able to watch it and see if the ecm is commanding it open and see where it actually is and see if the values match or not. If they don't match then you need a bypass valve.
    Nov 16 2015
    DFW
    Looks like he switched to stock and boost levels are correct or is that not the case?
    Dec 19 2010
    North CA
    Yes I changed to the stock program and was able to run at around 10psi
    It's really strange that it's acting up all of a sudden.
    Jan 14 2009
    pasadena md
    Well if you have Vag com or access to one. Just get that and a buddy and do some logging. And watch that bypass valve and see what its doing. If its not matching commanded then I would say that's an issue with the bypass valve. Or if it is then I would say something got corrupted and you will need to go back the apr dealer you got the tune and get them to put the software back in there fresh.
