Just R&R the clutch and flywheel and RMS. It is a Southbend stage 4 clutch that I've been running, just rebuilt, non sach unit clutch. Car is still on jack stands, no axles or driveshaft installed. Clutch bleed. In neutral, with clutch not pressed, the speedo shows 5 mph and axle brackets spinning, press the clutch in and speedo drops to 0mph. No unusual sounds and pedal feels pretty good. I've done this job a few times in the past.
If put in gear everything seems to be working.
Any ideas? Slave cylinder?
