I had an oil leak at the upper oil pan. Removed, cleaned sealed.
Ditto lower oil pan.
No have 'blinking red oil can' for low oil pressure warning.
I don't think I applied to much sealant so that squeezed out pieces could come off and plug oil pump pick up screen.
But I noticed that the oil pump pipes all had O rings on their ends (reused). Is it possible or common that those O rings are not seated properly or otherwise leak and cause the low oil pressure?
Aside from taking the lower oil pan off again (to gain access to the oil pump), any other checks?
I assume the oil pump did not just go bad from being removed and reinstalled?
Other ideas?
