    Dec 19 2011
    Colorado Springs
    Oil Cooler Adapter plate
    Hey everyone!!
    In preparation for my 3076 I'm looking to improve oil system capacity and cooling by adding an oil cooler where my OE SMIC used to be, but I'm trying to find a good source for the adapter plate. Any good sources?
    Looking for one similar to the one seen here.
    Hoping to find one with 2 x -10AN ports and an 1/8" NPT for a pressure gauge.
    Plan is to stuff an 11.5" X 10.75" 19 row cooler behind one of the grilles and throw a slim fan on the back with a thermostatic switch.
    - Dave
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Dec 19 2011
    Colorado Springs
    Bueler?
    Dec 05 2007
    Best brand is Mocal, but comes at a price. You want a thermostatic one. Non thermostatic and it will take a very long time for your oil to reach operating temp.
    When removing the stock cooler, you run the chance of overheating if the thermostat gets stuck closed. But the benefit is your oil gets hotter quicker. Oil bypasses the cooler into your engine. When it reaches a certain temp, it opens and goes through the exchanger then your block. But if thermostat gets stuck, it never circulates oil through the exchanger and you will overheat the oil due to no cooling.
    Safest is stock cooler with aftermarket sandwich plate. Warms up like stock. Then extra cooling capacity when sandwich plate thernostat opens. And remember, your oci will now require more oil because more volume to fill.
    As for oil pressure, use your stock port location. There is a vdo adapter. Cant recall thread pitches off the top of my head (on my cell phone and about to go to work, but I'll post links when I get home). I picked mine up from summit racing. It is a 3 way tee. Goes onto stock oil switch port. Then on the other ends, you place the stock switch, thread adapter on other port for metric to npt, and place your gauge oil pressure switch. This is how I have mine set up.
    Jan 24 2008
    Pennsylvania
    That's how I setup mine as well. For the heat exchanger, I sourced a Setrab with an integrated Spal electric fan (puller type), wired in a thermal switch so the fan would run when the oil temp is over a certain temperature, and mounted it horizontally below the washer fluid reservoir so the heat would be pulled through the exchanger and dumped out below the car through the end of the skid plate. This was one of the things I did to keep as much heat out of the engine bay as possible.
    This also kept it out of the way of intercooler piping.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Jan 09 2012
    MA
