Results 1 to 4 of 4
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Rs3 grill inserts with ACC/ Where to buy?
    I have a RS3 grill but my car came with adaptive Cruise control and I have the square'eye' in the middle. I was browsing the web and came across these pics.....
    This would be perfect....I would just need to buy the 2 lower inserts as my grill is pretty much the same minus the 2 inserts... Please steer me in the right direction...
    [IMG][/IMG]
    [IMG][/IMG]
    Below is actually my rs3 grill. The bottom part which is grey actually screws off and is separate. I'm thinking if I do not find a solution, then I will have to cut out the small hexs in between inside the grey part.
    [IMG][/IMG]
    Nov 16 2009
    2015 audi s3, 1998 jeep wrangler
    pittsburgh
    Yes, I am also curious as to if there is an rs3 or "blackout" grill made for the s3 with acc
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    I hope you are aware that the acc will have to be adapted if you move it. You may want to check with your dealer for the cost of an ACC alignment. I haven't looked at how it's mounted on the S3, most models are mounted to the bumper cover.
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by Z32drifter View Post
    Never knew this.......I guess all the guys that got new Intercoolers had to too? I am planning on getting an upgraded intercooler so I would do all this at the same time...
