Results 1 to 8 of 8
    Mar 03 2016
    Tahoe CA
    Passing CA smog wtih SAP delete
    Does anyone know if it is possible to pass CA smog with the 034motorsprosts Secondary Air Pump delete? I know it throws a CEL, is there a way on VAG around this? Take off CEL and allow to pass smog.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    what motor do you have?
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jun 29 2014
    America
    You won't pass if you have a CEL. You need to get it coded out.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    With the right tuner this can be coded out "properly" and allow it to pass SMOG.
    You have another problem though: the visual check. They're gonna look for the components and if they don't see them, they will fail your car.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    resistor wont throw codes
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Mar 03 2016
    Tahoe CA
    I have a shop that is fine with missing parts just have to get SAP coded out. Is there a code for it? or does the tuner usually write something?
    @grapebandit what do you mean resistor wont throw codes? Can I install that in place of the SAP?
    Thanks for the input!!
    Dec 13 2010
    FL
    Quote Originally Posted by antzing View Post
    you can literally just plug the resistor into the 2 pins on the SAP electrical plug or solder it in. I know it works on b5's, it should be the same for b6. the resistors can be had at radioshack. a pack of 5 cost $1.99. you need 300ohm 1/2 watt resistors
    said resistor works for SAP, N80, and N75. probably the n249 too
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Unfortunately that isn't going to work with the B6. The SAI is monitored by the front oxygen sensor. It is looking for specific changes in the A/F ratio. All the resistor will do is prevent an open circuit code when you remove the pump.
    Then 45 seconds after the SAI cycle completes the ECM turns the pump back on for 5 seconds and again checks the A/F ratio to confirm that the SAI works.
    Listen for it at your next cold start and you will notice a slight blip in the RPM as this occurs.
