I installed this when i replaced my motor and trans two months ago and I know there is a lot of NVH with this set up. I'm getting a noise every time I shift. It sounds like its coming from around the trans, but there is also the "clunk" I think coming from the back. I have the ECS rear diff mount and I have the Street Density rear diff carrier mounts as well. The only thing i can think of is that I tightened the ECS mount before letting the car idle. Almost like how your supposed to install snub mounts. What noises do you here from your JHM shifter upgrades if you have them?
