Results 1 to 7 of 7
    Jan 28 2016
    Unexplained vibration
    I have an 04 A4 1.8T manual and I have recently developed a vibration in the gas pedal starting around 35 mph and up. You can also hear it start at those speeds and is a dull wawawawa sound. Vibration can not be felt in the steering wheel, stick, or the brake and clutch pedals which makes me think it's not brakes or transmission. It does not make any more or less noise when going around a bend so I'm doubting it's a wheel bearing. It also continues to make the noise when at speed even when the clutch is pressed in so its not rpm specific. Since the noise/vibration started I have replaced both axles and put 4 new tires on so I know it's not that.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    engine mount?
    Jan 28 2016
    Quote Originally Posted by Luis_Heineken View Post
    engine mount?
    I know that one of the mounts has been leaking but wouldn't it cause the vibration all the time and not just at 35+ mph? I also just added a Frankenturbo which probably added a lot of stress to the mounts so maybe you're right. At this point I'm not too sure
    Jan 28 2016
    Anyone else have any ideas?
    Jan 28 2016
    Bump
    Jan 28 2016
    I just replaced all the engine mounts and it did not help. I tried jacking up one side of the car and twisting the tire to test the wheel bearings. Bearings seem ok but there is some "slop" in the front end. Could that cause the vibration even though I'm not feeling it in the steering wheel?
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Carrier bearing on the driveshaft?
