It seems impossible to drive my S4 smoothly. I've never driven another B6/B7 S4, so I'm curious how delicately other owners can control their throttles.
Owned this car 5 years now, and it has always acted the same. There's a fairly large gas pedal deadband where absolutely nothing happens. It's viewable in VCDS: I can start pressing the gas pedal and the throttle doesn't react until a certain degree of pedal travel is achieved.
Is this normal? Took the pedal off the car and inspected the inside - it's just contacts on a circuit board. The arm is rigid with the pedal, and the contacts definitely move across the surface of the board when I'm experiencing this.
Inside of gas pedal
The car is absolutely maddening to drive. Small, delicate throttle movements are impossible without either bogging or racing the engine. Starting from first is extremely difficult because I need to press the pedal until I notice the engine responding, then release the clutch while holding that precise electronic gas position, then quickly, yet gently, increase the throttle some arbitrary amount to get the car to act like any other "normal" manual car.
Throttle body alignment procedure done, no change in the value of the position sensors, no impact whatsoever. The issue is there's a fairly large region of the gas pedal where nothing happens.
