    Apr 15 2014
    Ottawa/Gatineau Canada
    Rear exhaust hangers (Avant) question
    At the below link you will see 2 hangers, one is the complete assembly and labeled as the "rear left"
    The next part down is just the rubber part and labeled as "rear right"
    Is this "rear right" part mislabeled and is the same rubber hanger used on the left side? I do not need to buy the whole assembly, and if the rubber part is the same on both sides...I will just buy 2 of the"rear right" rubber parts.
    http://www.autopartsway.ca/partlist..../pagenum1/tabs
    Thanks for the advice.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    They look identical on my sedan. I would assume them to be the same on the Avant.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    That is interesting. ECS along with a few other sites show only the rubber piece available for the rear right. Left is rubber and bracket.
    Dec 28 2006
    Western Maryland
    I just went out and looked at mine. They are the same. 8E0 253 147. The metal brackets are handed but the rubber hangers aren't.
    Disclaimer: I have a sedan and not an Avant. But I'm guessing they are the same.
    Apr 15 2014
    Nice, I am just going to order some of the runner hangers then.
    My left is drooping a bit low....temp fix...
