Results 1 to 7 of 7
    Junior Member Two Rings
    Jan 16 2016
    Dublin, California
    AWE Exhaust Fitment
    Will a B8 S4 AWE Touring Exhaust with resonated downpipes fit a B8.5 S4???
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    yes will fit fine. The only difference is the tip size. They AWE increased the tip size for the B8.5's Im sure if you want it to look right you can buy the tips from AWE if you want. Or just install it and see how it looks.
    Mar 21 2015
    AWE gave a bigger size for the 8.5 because the rear valance openings are bigger. You can only buy the tips if you were the original purchaser and I hear they are something like 3-4 hundred.
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Yea if it's from a B8 you'll just get 90 mm tips. I almost got them on my b8.5 but honestly the bigger 102 (?) mm tips fill out the openings way better and look sweet
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Registered User Four Rings ModBargains.com's Avatar
    Mar 09 2010
    La Habra/CA/USA
    Yes, the B8.5 S4 can take both the 90mm or 102mm tip options from AWE so you are good to go!
    Veteran Member Three Rings audinator's Avatar
    Nov 17 2005
    B9S4, 91 CRX, 85 CRX, 17 Thundra
    SoCali
    if it helps ... 2015 with AWE Touring 90mm tips ...
    2018 B9 S4 Daytona Gray | Rotor Gray
    . . . and many other Audi's over the years . . .
    Mar 21 2015
    Heres the 102
