01 A4 2.8l. Just finished doing the TB and components this week along with complete PCV system, VCGs cam caps/seals, tensioner seals and vacuum lines. Very stoked as there are zero oil leaks and car seemed to run great. When I drove it the 20 mins home two weeks ago it was leaking oil pretty bad and when I got to the driveway at low RPMs it was running rough. Figured because of oil leaks getting into plugs. Bank 2 plugs were black and sooty. Other side were just oily.
Two days ago I drove the car putting about 40 miles on it and ran fine. Yesterday after driving about 10 mins it started running rough at low RPMS almost stalling. Set the P0174 code and Po150 was pending. Both to do with Bank 2. 174 running lean and 150 O2 sensor malfunction I think.
As soon as I cleared the code while car was running it smoothed right out. I have an ultra gage hooked up. Doesn't do a lot but can read O2 voltages. I notice when car is cold. The rear two do pretty much nothing. No fluctuation. The front bank 1 is working but the bank 2 front is not really doing much. If I really knew what to look for or what the numbers meant I could give a better description.
Am I pretty safe to say that front bank 2 O2 sensor is prolly shot causing bad reading and making that bank run lean and clearing the codes resets monitors so all is OK until the monitors are ready again? When I finished the TB belt job I had to clear a code because forgot to plug rear cam sensor in. So after driving a while maybe it's why it started acting up yesterday until I reset codes again?
