I tried to check a couple of things in VCDS and I ran into some trouble. Can you elaborate why this is happening? I googled a bit and it said that these functionalities may be disabled on some ECU's.
I tried to check the IGNITION misfire count and the PDC distance value:
- The blocks 015, 016 and 017 in the 1-engine module give no value (brackets remain blank)
- The control module 76 for parking assist where you can read the PDC values is not reachable (OEM PDC works normally)
Here's the complete scan of all available modules on my ECU. 76 - Park Assist is not reachable...
Tuesday,22,March,2016,18:07:05:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Address 01: Engine
Protocol: CAN
Part No: 8E1 910 560
Component: 4.2L V8/4V FSI ª0080
Coding: 01040003180F0160
Shop #: WSC 00191
Address 03: ABS Brakes
Protocol: CAN
Part No: 8E0 910 517 G
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335
Address 08: Auto HVAC
Protocol: KW1281
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect.
Protocol: KW1281
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0704
Coding: 01021
Shop #: WSC 06335
Address 11: Engine II
Protocol: CAN
Shop #: WSC 00191
Address 15: Airbags
Protocol: CAN
Part No: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Coding: 0430712
Shop #: WSC 06335
Address 16: Steering wheel
Protocol: KW1281
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 06021
Shop #: WSC 06335
Address 17: Instruments
Protocol: KWP2000
Part No: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0030
Coding: 0023101
Shop #: WSC 63480
Address 25: Immobilizer
Protocol: KWP2000
Coding: 0023101
Shop #: WSC 63480
Address 31: Engine other
Protocol: CAN
Shop #: WSC 00191
Address 45: Inter. Monitor
Protocol: KW1281
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv.
Protocol: KW1281
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4035
Coding: 06762
Shop #: WSC 06335
Address 01: Engine
Protocol: CAN
Shop #: WSC 00191
Protocol: CAN
Coding: 0004533
Shop #: WSC 06335
Protocol: KW1281
Coding: 00000
Shop #: WSC 00000
Protocol: KW1281
Coding: 01021
Shop #: WSC 06335
Protocol: CAN
Shop #: WSC 00191
Address 15: Airbags
Protocol: CAN
Coding: 0430712
Shop #: WSC 06335
Protocol: KW1281
Coding: 06021
Shop #: WSC 06335
Protocol: KWP2000
Coding: 0023101
Shop #: WSC 63480
Protocol: KWP2000
Coding: 0023101
Shop #: WSC 63480
Protocol: CAN
Shop #: WSC 00191
Protocol: KW1281
Coding: 00001
Shop #: WSC 00000
Protocol: KW1281
Coding: 06762
Shop #: WSC 06335
Any help would be much appreciated, because I'm completely in the dark and tried googling for a solution 2 days straight with no luck.
