Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Input on hesitation at 4k rpm
    So I just had a thought and wanted some input on a "quirk" I've started to notice. I'm not too worried about it, but if it's fixable I'd like to. Car has a slight hesitation at 4k rpm that is pretty consistent. First thought was misfire/boost leak. Pressure tested and found no leaks, spark plugs are new ish, 2k miles bkr7e. Checked one and it looked fine gap was good. I'll check all later. 2.0 coil packs have 5k miles on them. So my question is if anyone knows of an issues with the vvt system on the car? Actuators sticking/failing? The rpm is so consistent and 4k makes sense to be when the vvt should kick in that I'm wondering if it could be an issue with that..
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Some one this week posted almost the same problems at exactly 4k rpm and it turnt out to be a leaky injector.
    What are ur fuel trims in block 32? And you say gap is good but didnt mention whats the gap at.
    Lastly any codes? Did u scan with vagcom
    Dec 14 2014
    PNW
    Quote Originally Posted by f4m0u5 View Post
    Some one this week posted almsot the same problems at exactly 4k rpm and it turnt out to be a leaky injector.
    What are ur fuel teims in block 32? And you say gablp is good but didnt mention whats the gap at.
    Gap is 028, never considered a fuel issue.
    Dont have vag com, I use a reader/blue tooth scanner. Wonder of my app can measure fuel trim, I'll check today.
    Aug 04 2014
    Gloucester MA USA
    You should invest the 20$ in a cheap vag cable. Some aftermarket readers dont show some codes and you can only see them with vagcom. I spent the other 99$ on the registered vag com so i could real all the measuring blocks such as 32
    Dec 14 2014
    PNW
    I plan to, just haven't got around to it as other more costly issue arose, I can measure fuel trim on the app but I don't think the obd2 scanner sends that info..
    Dec 14 2014
    PNW
    So I can read fuel trims what kind percentage should I see at idle, part and full throttles?
    Aug 04 2014
    Gloucester MA USA
    The long term fuel trims what you want. . Theres technically 4 different readings. Bank 1 idle/bank 1 part throttle. And the bank 2 idle bank2 part throttle.
    They should be around +/- 4-7%. But up to +/-10% is ok.
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    It was my post about the leaky injector, and turned out to be leaking intake manifold!
    Dec 14 2014
    PNW
    So I went about changing plugs and that helped with the 4k misfire at wot.. But now at around 10 psi under part throttle it's will miss occasionally..
    Dec 14 2014
    PNW
    I'll double check but I believe that my long term reading for both banks is about 4%
    Dec 14 2014
    PNW
    Quote Originally Posted by cjt671 View Post
    You guys think plug gap? I also havent checked for vac leaks but im at -20 inches at idle...
    Dec 14 2014
    PNW
    Dec 14 2014
    PNW
    Better pic,
    Dec 14 2014
    PNW
    Im gonna try plug gap.. It's at .028, think I should close it to .025 or go up to .032?
    Dec 10 2013
    Borden, Ontario, Canada
    Gap lower for easier ignition. .025 will be ok and is still within spec
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Dec 14 2014
    PNW
    .032 is factory spec and 2.0 conversion is supposed to allow running a larger gap, I might try both and see which runs better.
    Aug 04 2014
    Gloucester MA USA
    If you do have 2.0 coils that should be fine for gap. And did you store a misfire code for a certain cylinder? If it waas on one cyl only you can try swaping the coil to a different cyl to see if it follows
    Dec 14 2014
    PNW
    No codes otherwise I would have done that.. Fuel trims look fine to you? Maybe vac leak?
    Aug 04 2014
    Gloucester MA USA
    Those fuel trims look fine (but we dont know if thats part throttle or idle fuel trims because with vag com there are 4 different ltft not just 2 like the torque app and what not.) if they are in fact part throttle then it doesnt seem like a boost leak but ur idle fuel trims could be out of wack wich would tell you its a vac leak.without vag com its very hard to diagnose theese cars. You could be storing a code just ur aftermarket reader wont read it it might only read full codes that illuminate the dash.
    Aug 30 2007
    nyc
    I gapped my plugs to .024
    c5 A6 tip
    this n that
    Mar 07 2016
    2001 S4
    any success with smaller gap? did you boost leak test? it can run fine, like mine but at times it overboosts and computer shuts it down.
    Dec 14 2014
    PNW
    My bad forgot to specify this is at idle.
    Dec 14 2014
    PNW
    Quote Originally Posted by 616_S4 View Post
    It does generally run well, I won't have a chance to mess with the gap till tomorrow and I'll do some diagnostic pulls tomorrow, I'll post back if it helps,
    Aug 24 2014
    Newport Beach, CA
    I had the same issue back in the day, I had fresh coils and ICMs so that wasn't the issue. I gap mine at 0.024 and have no issues. Running copper NGK BKR7Es, going back to side fires since the NGKs don't last very long.
    2024 M3 Comp xDrive
    Dec 14 2014
    PNW
    Quote Originally Posted by christianb5s4 View Post
    Roger, I'll go with a smaller gap first then, and Im sure that bad plugs was my first issue with the misfire at wot, I run the bkr7e's and they were about 3k miles. New plugs and wot misfire is gone, just now I've got one at part throttle
    Aug 04 2014
    Gloucester MA USA
    Does the app ur using state long term fuel trim at idle or are you saying you just checked it while the car was at idle?
    My torque app only shows one or the other. Im not positive if its odle or part throttle. But from the looks of it urs is one or the other also.
    This isnt something you check while the cars idleing or while the cars driving under part throttle. You can actuslly check this with the car off its a stored number that doesnt move much except for when theres a problem or you just recently cleared your ecu faults
    Dec 14 2014
    PNW
    Mine reads long term short term and current readings for each bank
    Dec 14 2014
    PNW
    So I swapped my boost gauge reference from fuel pressure reg to dv because I noticed it would leak slightly occasionally..and over 70 miles my ltft bank 2 went from -0.8 to -1.8, related to my misfires possibly? I read some where that ltft value helps determine fueling during wot is this relevant to our cars?
    Gonna regap plugs this weekend
    Dec 14 2014
    PNW
    Gapped plugs.. Havent felt a misfire since, only been able to drive sort trips though
    Dec 14 2014
    PNW
    Drove home from work with the plugs at .025" which made the misfire worse and more consistent. Gapped plugs to .032 and the misfires are gone.
    Dec 14 2014
    PNW
    And they're back
    Dec 14 2014
    PNW
    Maf I'm thinking now.. Even though I just replaced it. Will not miss with maf unplugged
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Replace your FPR. I had similar conditions, 15 year old thing just wasn't holding pressure at all driving conditions, new one does. It's a $30 bosch part from rockauto.com.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Dec 14 2014
    PNW
    Quote Originally Posted by Timtheguru View Post
    Getting a replacement maf under warranty friday if it persists afterwards I'll look into replacing the fpr.
    Dec 10 2013
    I like how we both have misfires at WOT, but part throttle acceleration is fine lol
    IG: 24_et
    Sold:
    RIP:
    Dec 14 2014
    PNW
    Quote Originally Posted by Bordom View Post
    Lol my wot misfires are gone thankfully plugs were bad, so I can romp on her... But now just part throttle normal driving in anything over 10psi she'll misfire around 3500-4000k pretty badly, drives normal with maf unplugged
    Dec 30 2009
    Seriously, do it anyway.. you'll thank me later, I promise. :) Mine ran fine with MAF unplugged as well.. fyi.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Aug 24 2014
    Newport Beach, CA
    I'm waiting on a new FPR as well, those can certainly go bad and cause those issues. Can't wait to throw the new one in, a failing FPR can also cause longer cranking when trying to start up the car.
    2024 M3 Comp xDrive
    Dec 14 2014
    PNW
    I'll definitely look in to it as preventative as my focus is keeping this car healthy for stage 3,
    Car starts right up, I'm thinking mine's still in decent shape as I don't have idle, vac or wot issues
    Dec 14 2014
    PNW
    Still ducking at it.. new maf and the issue persists. 2nd gear part throttle will start bucking at 3k 3rd will do it at 4k
