I know I should just use a scanner and check but I'm away from home in a little town I guarantee there isn't a place near with a obd2 scanner. About a week ago my check engine light came on so I did the easy things check oil level, coolant level, and airfilter. (I took an air hose and blew the filter out)It was the air filter then the light didn't pop back up until 6minutes ago. The airfilter is almost new but it's pretty dusty around here. Any ideas till I can run the code?
B5S4
