Results 1 to 16 of 16
    Established Member Two Rings Jperez9627's Avatar
    Dec 06 2012
    1999 Honda civic, 2015 Kia soul
    California
    Hks ssqv bov questions
    So I put a hks ssqv bov in and now my car feels like it wants to die when I clear codes. Than goes to limp mode.... by the way I'm on a stage 1+ tune from motoza. I know I read that our cars hate bovs..... it sounds amazing so I had to at least give it a shot. Maybe the bov us leaking? Idk this sucks
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    The car can't read the air that the atmospheric dump valve is leaking and your car is dung because of it when you clear the codes the fuel trims go back to zero.
    Do yourself a favor and buy a billet dv from somewhere and clamp on a cone intake with a heat shield and you'll have bypass air sound and the car will still run properly.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Dung=dying
    Tapatalk is missing the edit button right now for me.
    Dec 06 2012
    California
    Okay.... does the car eventually adjust or does it just go crazy? I have a forge 007 hybrid diverter valve but the sound isn't as great as the hks. Can my tuner possibly tune in the hks?
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by Jperez9627 View Post
    problem is that your BOV is rejecting metered ("accounted for" by the MAF) air out of the system .
    ALL the air that goes through the MAF should be " consumed" by the engine.
    edit: is is doing that idling too ?? if so check if the BOV is completely closed at idle
    Dec 06 2012
    California
    It idles just fine... the issue is that it goes into limp mode after a few miles
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    what codes are you getting ?
    Dec 06 2012
    California
    Fuel trim....... I believe p0171.... I think that's a vac leak if I'm not mistaken
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    bov=big ol vacuum leak.
    lol.
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    Facepalms, upon facepalms. On more facepalms.
    Aug 26 2005
    Our ECUs can't accommodate BOVs because the mass air dumped to outside air has been metered by the MAF meter, and is a significant fraction of the total measured MAF. The ECU does not know about this, so the ECU injects the mass fuel for the MAF measured. However the measured MAF is more than the actual MAF, so the engine runs very rich fuel for a little while after a BOV boost release cycle.
    Vorsprung durch Technik
    Dec 06 2012
    California
    Hmmm... is there a way to run this setup? If anything I'll just get the dv adapter for bov. You guys think it would sound the same? If not somewhat similar? Could a ebay intake give me that sound with a dv?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    There seems to be some misinformation here.
    First off, and my entire post is predicated on this, I believe the SSQV is closed at idle.
    Second, you are getting a lean code. This means too much air. But if the BOV is closed at idle, it shouldn't be letting additional air in. The code you should be getting, as mentioned by diagnosticator, is a rich code. When the BOV vents, the computer will be injected to much fuel.
    Simply put your hand in fornt of the BOV at idle. Is it sucking air in? If not, you have a vacuum leak somewhere else. After you put the BOV in, did you cap off all the lines?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jul 14 2009
    Pasadena
    sell your b6.
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 06 2012
    California
    I capped them all off. I eliminated the boost resivor, and that just left the hose that leads to the intake. It's not leaking. .... so I gotz me a massive vac leak somewhere.... damn another journey to find my problem.
    Dec 06 2012
    California
    I would but I love my car..... and now I'm very invested in this.
