Had a check engine light come on and was by an advanced auto so I had them check it out. Said it was an Evap Leak. Took it to the shop for scheduled oil change and alignment and asked them to check it out. They said it was also throwing a thermostat and cooling system code. They gave me a laundry list of items to have checked out and I'm just wondering your take on the situation.
2005 B6 A4 S-Line
93,200 Miles
Timing Belt/Water Pump Remove and Replace (OEM) $1,056 ($426 Parts) Seems on point
Cooling System Expansion Tank Replace (Small Crack) $104 ($41.50 Parts)
Cooling Flange Leaking Rear Cylinder Head $279 ($38.40 Parts) Had this done by them in November for $342 after it blew open and I was stuck on the highway.
Thermostat Replace (OEM) $473 ($158 Parts)
Upper Control Arm Bushings (All 4) $439 ($155 Parts)
Engine Mounts Front Right & Left $634 ($300 Parts)
Replace Both Front CV Axles (Open Boots) $550 ($288 Parts)
Additional Recommended Replacements - Not Quoted
Original Spark Plugs Replaced
Valve Cover Gasket - Small Leak
Possible Cam Chain Tensioner Leaking
Headlight Sprayers Cracked - Cap Off
Transmission Leak - Out Put Seal Rear & "Elat Plug"
Front Nose Mount Cracked
Personally, I feel the shop is taking me for a ride. I understand some of these items are serious and he did not show them me first hand but I just dont know if I trust them. He didn't remember doing the coolant flange in November and gave some excuse about the thermostat being bad and throwing a code for the coolant sensor and flange. I just had it at the dealer (Audi of Denver) three weeks ago to replace the A/C Compressor ($1,450) and they mentioned the timing belt but didn't mention anything else above.
What do you guys think my priorities should be in getting her tip top? Additionally, I can do some maintenance (replaced idler and belt tensioner & alternator myself) just wondering what jobs I could take on myself.
Also, the shop is a high end dealership, so I'm wondering if they're just trying to get me to trade in for something newer. http://automotive-imports.com
