Results 1 to 9 of 9
    Established Member Two Rings noldevin's Avatar
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Remote Lock Woes
    Well I hate to have to start a thread on this but at this point I'm at a loss.
    Did a search and this hasn't come up so here we go...
    Since I bought my 05 last year the key remote hasn't worked. The previous owner said it just needed to be reprogrammed but I've had no such luck. The locks function fine using the interior buttons or using the key in the driver's door. All other comfort module functions seem to be working fine. Tried new batteries, the few different key-and-button-press combos i've seen, and re-syncing with vag-com.
    Today I tried another key I grabbed off Ebay and still no luck. I went into measuring block 006 where you're supposed to see if the remote is communicating in block 3, and instead of "0000" mine says "Not Oper."
    I checked the faults on the module and got this:
    4 Faults Found:
    01134 - Alarm Horn (H12)
    49-10 - No Communications - Intermittent
    01616 - Signal Wire to Interior Monitor
    01369 - Alarm triggered by Hood Switch ----- this one strikes me as odd because the alarm has not gone off ever since owning the car and i've cleared the codes recently
    35-00 - -
    01560 - Passenger Door
    59-10 - Can't Unlock - Intermittent - Also strikes me as odd but I think this one is from the gf trying to open the door before it gets a chance to unlock.
    The coding for the module is set to 11788.
    Any help would be greatly appreciated, I miss remote locks and have caught myself a few times trying to use the key to manually unlock my Mustang because I'm so used to it >_>
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Anyone?
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Bump
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    I had this same issue but mine was due to the antenna booster not being installed when I purchased the car. The PO had mocked up some crappy antenna booster but it did not provide a signal for the FOB. After installing an OEM antenna booster, the problem was fixed.
    Not sure if this is your same issue but may be worth a check.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Quote Originally Posted by MurkyRivers_A4 View Post
    Did yours indicate that the lock system was not operating in VCDS?
    Dec 17 2009
    Kentucky
    Quote Originally Posted by noldevin View Post
    At the time, I didnt have VCDS so I cannot answer that.
    Checking the antenna booster takes a couple seconds to do. Pull down the after upper panel above the rear seats and verify that its installed and plugged in.
    Again, Im not sure if this is your issue but it sounds very similar to mine.
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    I'll have to check that out. If that's what it is I'll have to wait for a used one to pop up cheap. Remote locks aren't worth $300 to me :/
    Dec 17 2009
    Kentucky
    I definitely didnt buy new. I got a hold of larry_fopps who was parting out an A4 and bought it off of him. There are plenty of cars being parted out in the Classifieds section.
    Dec 17 2009
    Kentucky
    Also, after fixing the antenna booster, I did get VCDS and ran the codes. This is what I got for that module.
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1512
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EBED2D3ECC77AE78-4B1A
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0002
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0002
    22 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Rear Right
    35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    01031 - Central Locking Key Switch; Driver Side; Unlock
    27-10 - Implausible Signal - Intermittent
    00913 - Window Regulator Switch; Front Right Driver (E81)
    00915 - Window Regulator Switch; Rear Right; Driver (E55)
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
    00912 - Window Regulator Switch; Front Left (E40)
    01801 - Door Warning Lamp; Drivers Side (W30)
    57-10 - Electric Circuit Failure - Intermittent
    01705 - Selection Switch for Mirror-Adjust (E48)
    01559 - Drivers Door
    01035 - Electric Window Thermal Protection Active; Passenger
    35-10 - - - Intermittent
    01332 - Door Control Module; Passenger Side (J387)
    53-10 - Supply Voltage Too Low - Intermittent
    00936 - Electric Window Switch in Front Passenger Door (E107).
    01561 - Rear left door
    01562 - Rear right door
