Originally Posted by
madyspop
I run 275's on a 9.5" wheel with a 32 offset on a lowered car and they don't rub, the 265 will clear with no issues.
I don't get this. I had 265 PSS on 9.5 wheels offset 35 on a lowered car and they would rub on the fender liner screws/clips on aggressive turns. Took the screws out and no problem. You have wider tire and 3mm more aggressive offset and no rub.
i now have 10 inch wheels offset 38 so 1/8 in more protrusion on wheel which puts it right about where your 9.5 are at with 32 and when I tried the 275 PSS there is no way. rubbed like crazy in the front even without the screw and clip. I had to go back to the 265 but I have a bit more stretch and gap than I would like even tho the wheels are 3.35mm more aggressive.
What brand tire do you use?
I am thinking if I find a 265 that is meatier or a 275 that is less meaty I can fill that gap a touch and have a bit more square sidewall.
I think 265 on 9.5 ET35 is perfect for the S6 but I get more concavity with the 10 inch wheel and if I can just find the right tire I will be in hog heaven.
