Results 1 to 8 of 8
    Established Member Two Rings jpjmustang's Avatar
    May 23 2013
    2014 Audi Q7 TDI - 2011 BMW 328I
    Missouri
    2006 A4 FWD - Transmission Oil Change
    I have a front wheel drive - bought it at 101K
    Im up to 181K still no issues with the tranny - but Im always nervious .......
    Does anyone know if there was a "standard transmission" for that year (or multiples) and what fluid do you replace it with (and where do you get yours)?
    JPJM
    [B]JPJMustang[/B]
    2014 Audi Q7 TDI 3.0 Prem +
    2012 Audi A6 3.0T Prem +
    2011 BMW 328i
    2004 BMW X3
    Oct 24 2015
    Perth, WA
    Transmission fluid (G052180A2) can be sourced from here https://www.ecstuning.com/Audi-B7_A4...luid/ES253196/
    Get 7L as you may need it. Also purchas a new drain and fill plug.
    You will also need a 12 Point Triple-Square 'XZN' Tamper Proof Wrench, Stubby, 16mm to remove the drain plug and a 10 mm hex socket to remove the fill plug.
    Lastly a hydraulic fluid hand pump to pump the new fluid in.
    Dirve the car, warm it up. Jack it up at both ends and make it fairly level. Remove the fill plug and then the drain plug to drain the fluid. Reinstall the drain plug, pump in fluid until it just overflows. Replace the fill plug and turn engine on and cycle through gears until VCDS shows around 41oC. Turn off, remove the fill plug repeat the fill until overflow, repeat until no more can be pumped in. Torque plugs to 49Nm and you're done.
    I did this on Thu night, took about an hour and half going slowly.
    Much smoother even when I didn't have any issues previously.
    Fluid was a brown/red dirt colour.
    My respray thread
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    I don't have a VCDS should still be able to do it ...
    Oct 24 2015
    Perth, WA
    Yeah, not a good idea, you have to monitor temps and stop it at 41oC and refil. Better to borrow one and do it properly.
    My respray thread
    Oct 24 2015
    Perth, WA
    My respray thread
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by Okedokey View Post
    Surely the right way to do it as many so-called 'Audi techs' wouldn't even have a clue of doing.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Other methods
    I've heard of people using infrared thermometers monitoring the temp of the pan /fluid.
    Oct 24 2015
    Perth, WA
    Yeah, id rather use what the car shows, but you have to remember, by the time the pan heats up to designated temps, the oil will be a lot hotter, so you have to factor that in.
    My respray thread
