The 2002 1.8 5 spd manual A4 that I've rebuilt was running and driving great until today. I was slowing down to turn onto a side road and down shifting into 3rd gear in preparation to make the turn. When I made the turn I shifted into 2nd gear and I thought I missed it because it only revved up when I tried to accelerate away, so I tried putting into 2nd again but there was nothing there. As I coasted to a stop I tried the other gears nothings there. You can put in 5th gear at idle let the clutch out and it sits there idling as happy as can be no change in rpm you can't tell from the engine runs that you put the car into gear and engaged the clutch. The transmission appears to shift through all of the gears normally the clutch pedal feels normal. Very strange it made no noise, no smell, and I can find no evidence of leaking fluid its like the clutch is not engaging the fly wheel. The previous owner converted this car from an automatic to a 5 spd manual so I'm hoping someone has an idea as to what went wrong with the clutch/transmission. Thank you in advance
