Results 1 to 30 of 30
    Veteran Member Three Rings Polski's Avatar
    Sep 21 2009
    B7 S-line Avant 2.0TFSI 6SMT
    Montreal
    DIY fixing "bloated" S-line door blades
    I've made a little DIY for those who can't/don't want to source a new/used door blade.
    I would label this a 1/10 in terms of mechanical complexity.
    Try it at your own risk, even though you were probably going to toss the blade out anyway.
    I couldn't find anything online that could fix the issue I had, so here it is:
    My door blade was sticking out to the point that opening the rear passenger door would make a loud pop noise (the rear door blade hitting the front door blade while opening the door). I would say it was sticking out a good 1/4 inch.
    In my case, the tabs and screws were fine, the blade simply had expanded from the inside due to water infiltration and rust building up. Decided I had nothing to loose by taking it apart and trying to fix it.
    Tools:
    - Cross head screwdriver
    - Flat head screwdriver
    - J-B Weld glue
    Step 1) Remove the two screws securing the door blade with the cross head screwdriver, then slide the blade to the left (passenger side) or to the right (driver's side).
    Step 2) With the blade out, remove the three plastic parts (1,2,3) as shown, I simply pried them out with the flat head. Warning, parts 1 and 3 will need to be broken off, no worries, J-B weld will hold them in place.
    Step 3) Gently pull back the plastic that was underneath, you will find the culprit that was pushing out the door blade (rust). Take a flat head screw driver and scrape it all out.
    Should look a little something like this when you're done.
    Step 4) Put some J-B weld along the whole line and snap parts (1,2,3) back to their original position. Make sure parts 1 and 3 are as flush as possible with the cover. Be careful not to get J-B weld into the threads of parts 1 and 3. Part 2 doesn't really need the J-B weld as it snaps back into position but I put some anyway. Let the glue cure, I used clamps on it over night so that nothing moves while it bonds, it also keeps part 1 and 3 flush.
    Part 1
    Part 2
    Step 5) Install the blade back in. I Remember to again glide it back in so the tabs line up properly, you can look from the side if the tabs are in their place. If the blade doesn't sit flush, one of the tabs probably didn't go into its socket.
    Here is the end result.
    The cost for this DIY is simply the amount of J-B weld used, thats about it, saves you the hassle of having to buy a door blade or even a full set since some buyers don't like spitting them up.
    These were B7 A4 S-line door blades, im assuming this can work on B6 or S4 door blades as well, but dont quote me on that.
    MontrealAudiClub
    Dec 23 2011
    Mine are pretty bad at the moment. I'll have to try this.
    Oct 24 2015
    Perth, WA
    I suspect that is from storing car outside? May be a small inconspicuous bead of silicon to prevent ingress?
    My respray thread
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    I thank you for this DIY. Nice job, the polish way. I've been wanting to fix these on my own car but haven't had the time to try to fix it. Thanks for delving into this.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Nov 15 2011
    Montreal | I sell in USD
    Good job making the diy Polski! I remove them once a year to clean under, I shoot Krown rust proofing on them and on the door side.
    *****I sell in USD*****
    Dec 30 2015
    RI
    Finally a DIY for this!
    My Saturday project, good write up!
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Axis View Post
    Seems like a good project. Do you just brush the Krown on the door?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 15 2011
    Quote Originally Posted by mtroxel View Post
    Comes in an spray bottle at my local parts store. I get the car treated ince a year too.
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    pretty neat fix. I was looking at doing this but never did. Now I am going to try it with my spare set to throw on the avant
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Jan 24 2013
    Chicago
    It probably doesn't help keeping the car outside, but after removing the rust it makes me wonder why they placed these metal inserts in the first place.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Denio24 View Post
    Yeah, you could also get some phosphoric acid to nuetralise the rust and if you're super keen an epoxy primer rust proof paint. Then add a nice bead of silicon, and you will not have to do this again.
    My respray thread
    Jan 24 2013
    Chicago
    Ok I have to say I just tried this, and the door blades are still the same. When the phillips screws are screwed in, the door blades go back to the same old sticking out position.
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    I had the same issue as you. Tried this diy last year and didn't work at all. I gave it another shot a month or so ago, and actually pulled the door blade apart. the painted part is plastic welded to the piece that attaches to the door. Break the plastic welds, clean everything out and then re glue or plastic weld.
    Before:
    After:
    Jan 24 2013
    Chicago
    Quote Originally Posted by Danaldson View Post
    Did you end up removing the metal part altogether?
    Aug 28 2014
    Calgary, Canada.
    I hope polski doesnt mind me editing his photo, but yes, you need to remove what he did here in the photo and clean out all the gunk, but you also need to break apart the welded plastic along the thick red line and the painted exterior portion will come apart from the inner assembly.
    [IMG]180t8p by daniel donaldson, on Flickr[/IMG]
    Sep 21 2009
    Montreal
    I'm glad you guys liked it!
    Denio24, your door blades might have more oxidation on the inside than mine did, I would try what Danaldson suggested and take the whole thing apart at this point.
    Its very important that the two little pieces with the thread are as flush as possible with the side plastic when glueing it back.
    I even glued mine in a bit deeper than flush, its hard to see from this angle:
    MontrealAudiClub
    Sep 21 2009
    Montreal
    Thank you!
    thats a good call, I'll definitely go pick some up.
    MontrealAudiClub
    Apr 17 2016
    kc
    Just fixed my warped blades this morning. Didnt have jb weld so I used my wife's hot glue gun. Hope it holds. Thx for the info!
    Feb 25 2012
    Hudson, Qc.
    Will try this real soon, same problem with both back doors on the avant also. Thanks for the DIY !
    Feb 24 2004
    Minneapolis
    Did mine a couple weeks ago. None needed any attention, just cleaned them out good. But, on the RR door there was just a bit of rust starting in the door steel around the screw holes so take a good look for that too. I sanded with a Dremel wire brush, primed and painted. Doesn't look pretty, but doesn't need to. Let it cure for a week before I put the blade back on. And even then I put a thin layer of RTV on the blade where it presses against the steel just to cushion it a bit. Let that cure for a couple days before putting it all back together.
    Senior Member Two Rings Mech_Mike412's Avatar
    Jul 06 2016
    Pittsburgh, PA USA
    What's the best/cleanest way to break the plastic welds?
    Sent from my SM-G950U using Tapatalk
    2008 Audi A4 Quattro S-Line 6MT
    K&N Filter - ECS Turbo Inlet Hose - ECS Vent Boost Gauge - GFB Diverter Valve - Morimoto 3000K HID Fogs - JHM Stage 1 93oct - CTS Charge Pipes - Custom Catback, CTS Mufflers
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Mech_Mike412 View Post
    Not sure what you mean. Mine pretty much came right off. No plastic welds to deal with.
    Jul 06 2016
    Pittsburgh, PA USA
    I thought someone talked about taking the whole blade apart too, not just the three pieces. The bow on mine is pretty bad. I already cleaned out the rust but I'm not sure if that will be enough considering the amount of bow mine has
    Junior Member Two Rings
    Apr 30 2017
    Denver Colorado
    I did this on my avant only I did not re use the metal pieces inside the blades themselves. I threw them away and just JB welded the door blade to the car itself and boom was done and good to go. Has been solid and held in place for 6 months now. Keep in mind I live in the High rockies so the car is always subject to harsh weather conditions.
    Established Member Two Rings tigger_78's Avatar
    Oct 30 2013
    Did something similar - I completely disassembled each blade and removed the metal strip that is prone to rusting (just a poor design decision IMO - its not needed if using some type of glue/adhesive afterwards). Throughly cleaned each piece and then used JB weld to put everything back together. No more worrying about future rusting and I can still remove the blades from the doors to clean out any dirt that accumulates (and wow, can it build up!).
    2008 A4 3.2 Avant Titanium Ibis White
    2008 A3 3.2 S-Line Ice Silver (for the missus)
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    I just used this DIY for one of my S4 blades... ended up taking it all apart to remove the metal strip completely since some of it wasn't completely rusted and couldn't scrape it out. Besides, with the metal removed completely, should also prevent future rusting completely (like poster above mentioned). Also agree it's a poor design, not sure why it wasn't made completely from plastic.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Feb 23 2019
    Central Connecticut, USA
    Quote Originally Posted by fR3ZNO View Post
    Mega bump. Any photos of how to bonded them back together? I removed the metal strip, but since there was nothing behind the part that slides and locks to the studs on the door I filled it with silicone. Put the blade on once it cured and it looked awful. Gaps were horrendous.
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    I cleaned it out and put the metal piece back in. I JB welded it and the plastic end pieces as close to the blade skin as possible. The metal piece and its slides seem necessary to keep it tight to the door.
    Mar 27 2021
    '93 Jeep Wrangler - built for off roading,'06 Acura RL '09 Mini Cooper S '07 Yamaha FZ6 '04 Sprinter
    Clayton NC
    wish the pictures were still there to see.... dang it all.
    Established Member Two Rings simon b's Avatar
    Apr 25 2013
    Lorraine, Qc
    Yeah bummer about the pictures
