    Dec 11 2015
    PA
    Can't remove headlight, bracket connected to bottom of light
    They are Depo lights. They came on the car when my brother purchased it. I'm trying to remove the light to install a HID kit onto it.
    Top two T30 screws are removed. There are no other screws to remove, none behind the light fastening it.... just those.
    The problem is there is this sort of bracket under the headlight with what looks like a screw securing it to the bottom of the light. I have no clue how to get in there to remove the light to install the kit.
    Please see video:
    https://vid.me/xVn2
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Here. There are 2 bolts in the back which can be easy to miss. They just need to be loosened, not removed. Then the headlight will slide right out.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Dec 11 2015
    PA
    There were no bolts in the back to remove.. There was this bracket that was screwed into the bottom of the headlight. Looks like i'm missing the bracket that goes under the headlight (where the bolts in the back are supposed to connect to).
    https://vid.me/Nmut
    Apr 15 2014
    Ottawa/Gatineau Canada
    yup... you are missing a headlight tray (or 2)
    Time to go to the wreckers ;)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 11 2015
    PA
    Quote Originally Posted by Luxus Panzer View Post
    Thanks,
    I just made a post in the classifieds for em
