Results 1 to 17 of 17
    Senior Member Three Rings qtek16's Avatar
    Jul 18 2004
    01 s4, 11 Yukon Denali, 08 TBSS, 94 300zx, Sold 01 A4
    Yeey! Fault code!
    over the weekend i threw a code.
    the code was for the car running lean in the fuel trim bank 1. Fault 17545
    system to lean p1137-35-00.
    Did a few things, cleared it now waiting to see whats up.
    Any suggestions in the meantime?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Have you changed your spark plugs lately?
    Jul 18 2004
    yess sir ;) changing those coppers quite frequently.
    Jul 07 2004
    socal
    Check your fpr vac line, when those start to leak they do cause a lean issue at part throttle if your in boost.
    Jul 18 2004
    will do. is there just one comming off of it? cant remember
    yes, theres just one line for the fpr
    check any of the braided hoses on and around your engine, they crack/tear over time
    if all hoses check ok and your dbw then a maf would be a good place to start
    contact via email please.
    Jul 18 2004
    yeah i have been wanting to change those braided lines just havent had the time. wouldnt it be a code related to the maf if it was that?
    Jul 07 2004
    socal
    You will only get a maf code if the maf ic completely dead, this will be in the form of a "low maf voltage".
    If the maf is starting to die out causing the g/s readings to get lower, this can cause the car to go lean.
    Jul 18 2004
    what is the norm for the maf readings? i have it all logged just have to go back and look
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Hey could this be caused by installing the maf backwards while installing the intake, i dont think you installed it wrong but its just a sugestion. take a look
    Jul 18 2004
    haha come on nizmo! im not that dumb haha. jp. yeah i even double checked that, and made sure all things were connected and fully tightened down. ;) i knew that would make u happy haha
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    i had the same code, was running lean and stalling. took out MAF cleaned it with carb cleaner, and let it air dry. problem went away and CEL also went away.................
    my problems are with a possible timing belt failure for now..........good luck with your car though.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Jul 18 2004
    im not stalling which is good haha for now anyway. i thought cleaning it could mess it up worse
    Sep 01 2005
    nope, just use carb cleaner, and make sure to let it air dry, do not us an air compressor or anything like that as the MAF has small fibers which can get messed up using compressed air............
    Jul 18 2004
    where did u pick that carb cleaner up at?
    Sep 01 2005
    any auto parts store, even wal-mart has it
    Jul 18 2004
    just what like a spray can and spray it on it? i dont wanna screw it up i know how sensitive it is
