2000 , A6 Avant, 2.8 Tip, 161,000 miles. Original owner.
I'm about to do 2nd full timing belt service. Last TB service was done at 90,000. At last service Crank and Camshaft seals were dry and were not replaced. This time I have an ECS ultimate plus kit that includes crank and cam seals, just in case.
I've read postings about how removal of the crank bolt could result in spinning the crank pulley and destroying the key and keyway. This happens even with the crank pin installed. Something about the crank bolt itself corroding onto the sprocket. Blauparts actually suggests leaving the crank bolt & seal alone if there is no sign of leakage.
I'm assuming this has happened often enough for them to post this warning on their site. Have any of you had this happen?
If I do find the crank seal is weeping & needs to be replaced, is there any way to hold the crank sprocket to prevent it from spinning when I attempt to remove that damn bolt, that's been in place for 16 years.
Thanks for advice.
