Results 1 to 6 of 6
    Feb 10 2012
    B8 S4
    SF|CA
    034motorsport solid rear sway bar >3k
    034MOTORSPORT SOLID REAR SWAY BAR + Hardware
    less than 3K miles. I purchased it directly from 034 in Fremont at their facility. Ended up buying a newer S4 a couple months later. This has literally been sitting in my garage. This upgrade greatly helped reduce body roll, making freeway entrances much more fun!
    $160.00 + shipping (~$20.00 FedEx ground, its heavy)
    PM if interested, Local Pick up preferred
    I accept cash, venmo, paypal
    Located in San Francisco, California
    034 Description:
    034Motorsport B6/B7 Audi A4/S4/RS4 Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required. The addition of a stiffer front bar introduces even more push, requiring an even bigger bar in the back. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
    Features:
    100% - 125% Increased Sway Bar Rate (Over Stock RS4 Rear Sway Bar)
    25.4mm Diameter
    Solid Spring Steel Construction
    2-Way Adjustable
    Designed to be used in conjunction with the stock front sway bar.
    B8 S4 | Black Optics | 6MT | Sport Diff | Carbon Atlas | APR Stage II | StaSiS Ohlins SL | AWE Touring | Eurocode Stage III Clutch/LWFW | Eurocode ÜSS | Eurocode Alu Kruez | Enlaes Duck tail | Deval F/R carbon diffuser | O Carbon dash surround | Valentine V1
    Active Member One Ring Pizzo2007's Avatar
    Feb 02 2016
    Lancaster, PA
    Ill take it. PM me with info to send money
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    Dam pizzo, you're fast. Haha let me know if this gets sold :)
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I want
    Jan 24 2010
    norcal
    Located in sf! I can pick up from you asap!!
    Feb 10 2012
    B8 S4
    SF|CA
    sold
