034MOTORSPORT SOLID REAR SWAY BAR + Hardware
less than 3K miles. I purchased it directly from 034 in Fremont at their facility. Ended up buying a newer S4 a couple months later. This has literally been sitting in my garage. This upgrade greatly helped reduce body roll, making freeway entrances much more fun!
$160.00 + shipping (~$20.00 FedEx ground, its heavy)
Local Pick up preferred
I accept cash, venmo, paypal
Located in San Francisco, California
034 Description:
034Motorsport B6/B7 Audi A4/S4/RS4 Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required. The addition of a stiffer front bar introduces even more push, requiring an even bigger bar in the back. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
Features:
100% - 125% Increased Sway Bar Rate (Over Stock RS4 Rear Sway Bar)
25.4mm Diameter
Solid Spring Steel Construction
2-Way Adjustable
Designed to be used in conjunction with the stock front sway bar.
