    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Torque plate questions
    For those that have built your engine. Did you use a torque plate? Do you have oil consumption issues?
    Mar 24 2013
    Oakdale, CT
    Yes and yes, but they are likely unrelated.
    -Adam
    Dec 23 2011
    If you are going through the work to build your engine I would make sure a torque plate is used.
    Mar 24 2013
    Oakdale, CT
    I wouldn't bother if you are just ball honing and using stock diameter pistons. Definitely use it if you are boring the block though.
    -Adam
    Mar 05 2014
    phoenix/az/usa
    Yeah, it's being bored to 83mm and the machinest I just went to see told me he doesn't think I need to even though I told him I already had a rental lined up. Everything else about the place seemed good but now I was skeptical cause he didn't want to use it even though I told him I already was getting it.
