    Aug 10 2015
    RIP 3000GT VR4 w/15g's
    Dorr MI (Grand Rapids Area)
    ATW to AWM Questions
    I know I know it's been asked a million times but I've searched and the information is very conflicting going back years.
    So I got a good deal on a used k04 and would like to swap to the wideband awm ecu.
    My question is if I use the harness pictured below will it trigger any CEL's?
    I would need a CH box correct?
    I would be getting a tune and having the vvt coded out.
    Jan 03 2015
    Vancouver British Columbia
    I used the same harness. Works great, you can follow the instructions off of the Unitronics site.
    2001A41.8TQM Cat delete, 3"exhaust Turbonetics T3/T4 .63 A/R@18PSI, ATP Exhaust manifold, precision Turbo 39mm wastegate, Forge Splitter, FMIC, 80mm TB, SEM Motorsports Intake, AEB ported/polished, 3 angle valve seats with Supertech inconel exhaust valves/SS Intake, upgraded valve springs/ TI retainers, ARP head stud/main bearing stud kit, Skat rods/stock pistons, solid motor mounts, race density trans/snub/diff carrier mounts, stage 4 clutch with SM12lb flywheel, tuning by Motoza Performance
    Jan 03 2015
    Sorry, yes you need a CH box you will pull a VVT CEL but that can be coded out easily like you mentioned.
    Aug 10 2015
    Last question, what ecus will work?
    part#?
    Out of what cars? (Audi or passast)
    My car is 2000 atw 1.8TQM
    Just want to make sure I'm getting the correct ecu
    Jan 03 2015
    I just went through a mass of trouble trying to get an ecu out of a Passat to work with my 2000 A4, it ended up not being possible because of an issue with the transmission coding. Engine runs great with it but my auto trans won't shift manually or by itself so stay away from VW ECU's
    Best bet is to just get the 4B0 906 018 CH that everyone uses and be done with it. I ended up buying one yesterday off of eBay for $53 and I'm having it drop shipped to Motoza.
    There's a list one one of the Audi sites with all the cross compatibility but I can't find it at the moment.
