Results 1 to 6 of 6
    Veteran Member Four Rings fasteddy91's Avatar
    Jan 04 2013
    1991 Toyota MR2 Turbo
    Concord CA
    A5 to S5 trunk lid swap....any tips or any snags to avoid?
    Hey fellas
    I found a good deal on a used S5 trunk lid that I am going to have painted and installed on my A5. I tried searching for any threads on how to swap lids without luck. My brothers brother in law who is the owner of the shop is going to paint it and help me with the installation. I'm pretty sure he's got a good idea on what is involved but wanted to see if there was anyone out there with first hand experience on doing this.
    I figured I would need to remove the trunk liner and carefully start disconnecting the tail light harnesses and trunk actuator then unbolt the hinges.
    Any advice would be appreciated!
    2014 Misano red A5. S line Competition Package 6spd manual.
    2015 Brilliant Red R8 V8 6 spd manual.
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    @mops did an s5 trunk swap, he may have some insight
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Jan 04 2013
    Concord CA
    Quote Originally Posted by Sweep View Post
    Haha...already asked him...his shop did it so he doesn't know. Thanks for the suggestion though.
    Jan 04 2013
    Concord CA
    Just picked up the S5 trunk lid from FedEx freight. I started to disassemble the wiring, the inside trunk lid liner, reverse lights and trunk sensor button. All in all not too bad and pretty straight forward. I think the hardest part or the part you have to be very careful with is when removing the three bolts on each side of the trunk lid that holds it to hinges. You'll need a friend to help you there.
    I'll be taking the lid to my brother in law shortly and post some pics when it's done.
    Established Member Three Rings Nate B.'s Avatar
    Dec 01 2014
    Washington State
    Let me know how this goes. I've thought about it myself, if I could find a used one for cheap enough.
    Jan 04 2013
    Concord CA
    Will do...there's a few on eBay...the one I got was in mint shape...I guess I lucked out.
