Results 1 to 11 of 11
    Active Member One Ring MSHAZOR's Avatar
    Feb 21 2016
    16' E550 Coupe
    Nj
    B5 S4 Upper Oil Pan Replacement: Need Help
    Long story short, a few weeks back I hydroplaned and destroyed both oil pans, oil pump, chain and oil cooler. I've removed all bolts from the pans, removed what was left of the lower pan, and now am trying to remove the upper pan. The upper pan seems to be stuck in the rear (passenger side) corner by a cylindrical piece that sticks out about a half centimeter on one side and a centimeter on the other (in reference to the new pan). I have removed all bolts from the back of the pan, and to make sure, I put the old bolts into corresponding positions in the new pan. The pan will move quite a bit on all sides but wont come down where that cylinder is which is in between two other parts of my engine, the transmission and something else. I have been at this job nearly every day for 3 weeks trying to figure out what to do to finish it and am in some serious need of help as I need to find a way to get it back home in a month after school ends.
    First, is there any advice for removing the upper oil pan from my engine, and secondly, is there anyone out there in the Southern Philadelphia/Medford, NJ region willing to help me finish this job? I have bought all replacement parts, including all fluids, gasket, filter and pans and just lack the knowledge to complete the task.
    My car is at a friends house sitting in a barn for the time being. Right now it's on jack stands and I have access to a large assortment of tools including low and high torque impact wrenches.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    I believe the cylindrical piece you are referring to, is the oil return line for the turbo? yeah? no?
    Feb 21 2016
    16' E550 Coupe
    Nj
    No, it was a housing for a bolt.
    Sorry, Im new and I'm not sure how to post pictures, try this.
    https://pixlr.com/express/?method=po...19_142008.jpg#
    Jul 23 2012
    Pullman, WA
    Pic is not working.
    Feb 21 2016
    16' E550 Coupe
    Nj
    [email protected]
    If you still can't get the link to work, you can email me and I'll send you a picture so you can see what I'm talking about.
    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    I think subframe needs to removed to fully remove the upper pan. The only thing that holds the upper pan to the block, after the oil pump has been fully removed, is the m6 boots (12~14 can't remember) and the two m8 bolts in the rear. Two of the m6 bolts hold the pan to the rear main seal and can be hard to see.
    Active Member Three Rings auditrackspeed's Avatar
    Jun 17 2014
    oh god im sorry dude .... id just pull the engine foreal
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Quote Originally Posted by achb5 View Post
    This^ and I'd recommend remove the engine if you have the means, hoist, stand, and like a wooden pallet is what I mean hah I know it will take more time but every step along the way would be so much easier
    Aug 24 2005
    2001.5 Audi S4
    los angeles
    Did this a while back. Would'nt wish it on my worst enemy. Hope the pics help.
    Got ToTs?
    Feb 21 2016
    16' E550 Coupe
    Nj
    Thanks for the Pictures. I had already removed the subframe and the pump/chain were destroyed by the impact of the 8 inch margin that I slammed into. I was really hoping to not have to remove my engine since I don't have access to a hoist. But, thanks for all of the information, I'll see what I can get done. Also, in the picture above, The corner I'm talking about is the far left corner of the pan if you're looking straight at the screen. Thats where my pan is stuck. Everything else will move but that.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    jumpstv4. you are a genius, removing the oil pump gear instead of struggling with it.
    for the record, i know it can be done without removing the subframe, its just a real pain in the ass. and doing it without a hoist of some sort it probably not gonna happen.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
