Results 1 to 8 of 8
    Mar 01 2011
    Nanuet NY
    Need your help: I have no electrical power at all
    I used electrical cleaner spray on the maf sensor and connector because i got a code figured i clean it and give it a try. A few ppl on here said it worked. i put the key in the ign on the acc pos played with the radio for a sec and when i turned key to the on pos. i think i heard a pop and all the power cut. i have no power what so ever. i have checked all the fuses by the door panel and the by the ecu. Is there like a main power relay or fuse i'm missing?
    Thanks for your help
    Carlos
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Did you wait a few hours to let the maf cleaner fully dry? If you put it in wet and started the car, you could have short circuit your ecu, frying it.
    Check all relays inside the ecu again
    2008 A4 S-line 2.0T
    JHM Stage 2
    Account Terminated Four Rings
    Jan 15 2016
    '08 A4 2.0 Avant 6MT S-Line Ti
    SoCal 626
    Maf cleaner dries really fast, I think it would be unlikely that even if it was still wet that it would fry the Ecu. If anything probably a fuse/relay you missed.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Fast dry or not, its very likely that moister will fry the ECU
    Ask me how I know. Always wait a few hours
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 01 2011
    Nanuet NY
    Solved update: This is pretty bizarre. I noticed that the neg post/cable was really HOT so i disconnected the battery. I then test again all relays and fuses, also tested all cables continuity it was all good. So my dad popped the battery back because he thought i didn't see it, boom everything worked like if nothing happened. super weird.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by reno808 View Post
    Ah ok. Not bizarre at all actually.
    Your battery post was hot due to arcing, which is due to poor contact or high resistance due to dirty contacts. Clean your battery posts and make sure the terminals are seated nice and tight :)
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 01 2011
    Nanuet NY
    Quote Originally Posted by Schweini View Post
    Thanks will do
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    My pleasure
    2008 A4 S-line 2.0T
    JHM Stage 2
