Results 1 to 29 of 29
    Aug 09 2011
    Brooklyn, NY
    Anyone change their own oil?
    Some of us are not under warranty and do our own oil changes.
    Does any one use an oil extractor? If yes, what brand do you use or recommend?
    I know the oil level is electronically monitored and the dipstick channel may have a plug and not an actual stick. (wondering if the extractor can still be used.)
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I use a pump/pneumatic version of the mityvac purchased off of eBay. Mine is a 9L and works like a champ. Owning a B8.5 platform, I can generally change my oil in about 20mins (15 for the extraction and another 5 for the filter). I have also used it to change my wife's RX350 oil. Both times, virtually mess free, even with the dumping of the oil into an oil reserve. If you do purchase one, I would highly recommend one which holds at least 6L. Some extractors hold much less and the last thing you want to do, is to empty your extractor in the middle of an oil change.
    A couple of common questions people ask: Yes, you can extract virtually the same amount of oil as you would from the oil pan bolt. Yes, you can use it on a platform that has the dipstick plug.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I use this one.
    http://www.alloymarine.com/index/suckup.htm
    It was available at a local marine shop. Works well
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Aug 09 2011
    Brooklyn, NY
    Second Question what size socket for the Oil Filter cover?
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by gk1 View Post
    I use this one.
    Thanks for the reply. It states it's only 2.5 qts. I'm going to assume that you stop and discard the oil several times during the whole process.
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    I will be this weekend and noticed there really isn't a set of DIY instructions so maybe I'll make some. For what it is worth, while the suction pumps are nice, you can certainly do it the old school way and pull the belly pan to access the drain plug. I will likely go this route for at least this 1st time as I don't have a pump and need to take a lot apart as I'm also doing the RS6 style grille, the SC pulley, air filter, cabin filter and installing a radiator and oil cooler guard. I've seen a lot of B8 guys and a few C7 guys with punctures to one or the other due to the size of the openings with the grilles. I'll likely do at least some pics of what I make as a low cost solution.
    Do it right, or don't bother.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by SPONGE View Post
    LOL. It's 2.5 gallons. :)
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Aug 09 2011
    Brooklyn, NY
    Zap. Reading is fundamental. Thanks for the clarification, and the humor.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by PKmode View Post
    I do not have a garage and want to be able to do it without having to jack up the car. or borrower a friends place or paying for a mechanic / Quick Lube spot do it.
    You are taking on a nice project in combination to the oil change. Your car should drive butter smooth and look better once your done. Best part you spend sweat equity and get quality bonding time with your car. When you get a chance let me know the sprocket size for the oil filter cover. I don't want to use a wrench and scruff up the cap.
    Mar 14 2016
    Cleveland, OH
    IIRC they still come with a drain plug on most models that you can use.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by Clipse3GT View Post
    All oil pans should have a drain plug, that is known. (Drain plug washers / Threads can be compromised with frequent removal.) cheap part to replace and can be upgraded to a magnetic one as well. But rather not get on my back for oil changes nor worry about oil leaks from the plug.
    Thank you I would like to invest in an oil extractor (as this will save time and is easier (less leg work) than removing the skid plate and the conventional method.)
    Established Member Two Rings Drewabrewer's Avatar
    Feb 12 2016
    2009%20Q5%20Prestige
    Paducah, Ky, USA
    I have a magnetic drain plug and do it myself. Just make sure and change the washer each time. In my opinion you get more oil out this way. I've been told by several Audi mechanics that suction is mostly done for efficiency. I've always changed my oil in 3 different audis and I've never had any issues. That's just my 2 cents though. I'm by no means a mechanic or a professional in the matter.
    Mar 14 2016
    Cleveland, OH
    The other option they make: https://www.fumotooildrainvalve.com/
    Its just a drain valve. You install it once and it will simply drain the oil when you need to do it. Without working about stripping out the pan. You can just route some hose to the area you want to drain to. But a mightyvac pump or such will work as well without getting under the car.
    Established Member Two Rings cooncified's Avatar
    Oct 16 2013
    Orange County
    My 2012 A7 3.0 requires a 36mm. Yours should be the same.
    Oil changes are extremely easy on these motors.
    Senior Member Four Rings eyeloveteeth's Avatar
    Jan 07 2015
    weed wacker, lawn mower, some tools, air compressor
    NoVA
    last time i tried to top off my oil, i accidentally poured it into the Coolant tank...so nope, lesson learned.
    Oct 16 2013
    Orange County
    Quote Originally Posted by eyeloveteeth View Post
    Not sure I would have admitted that one... haha. Did you at least realize before driving it?
    Sep 19 2005
    Milwaukee, WI USA
    Correct on the 36mm socket
    Established Member Two Rings veeder's Avatar
    Feb 23 2010
    Mustang Saleen S281
    Windsor, Ontario
    The question I have, how do you change the filter without jacking up the car. If you have to jack the car ip and remove the belly pan to access the filter, why not just undo the oil pan drain. I could understand of the filter was accessible from the top the extraction makes sense.
    2013 Audi S6
    APR Stage 1
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by veeder View Post
    On the 3.0T the filter is on top.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 14 2006
    Cleveland, OH
    I've checked my own oil with my thumb, pinkie and ring finger. Does that count for anytihng?
    Feb 23 2010
    Mustang Saleen S281
    Windsor, Ontario
    Ah that makes sense if the filter is on top. On the S6, the filter and drain plug are next to one another
    2013 Audi S6
    APR Stage 1
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by cooncified View Post
    Thanks greatly appreciated.
    Junior Member Two Rings
    Jun 30 2012
    FWIW, I have always changed my oild since day 1. I put in one of these 4 years ago and cut out a small access panel in the belly cover. Oil changes are 20 min. Here it is installed:
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Oct 16 2013
    Orange County
    Quote Originally Posted by bartenderfloyd View Post
    I need to do that... Longest part of the process is accessing the nut and trying to keep clean while removing it.
    Sep 19 2005
    Milwaukee, WI USA
    Really? The four triple squares are that hard to remove you'd rather cut a hole in you're belly pan? That's hoaky and lazy. I just did my oil change yesterday. The whole process is 20-30mins which is normal for any car.
    Oct 16 2013
    Orange County
    I want to swap the plug for the drain valve he is showing. Belly pan (if that's what it is called?) removal is easy.
    Sep 19 2005
    Milwaukee, WI USA
    Ah, he mentioned cutting an access hole and you quoted it so I was thinking of the hole. Right after I was cruising FB and saw on an Audi page someone posting a pic of a 2014 A6 with a chopped up belly pan after a quick lube. SMH. Worse yet is when the quick lube place throws away your belly pan all together.
    Anyways, keep your belly pan in tact people. It's there for a reason. I'll admit the difference from a well place small access hole as Floyd mentioned is probably negligible (dirt and airflow disruption) but just take out the 4 screws. If it's the triple square heads, replace them with a something more std. My $0.02 so take it FWIW.
    Mar 14 2016
    Cleveland, OH
    Look at post #13. It has the link where you can get a genuine drain valve.
