Results 1 to 6 of 6
    Nov 18 2014
    Intermittent soft brake pedal
    Hi all,
    I just got front and rear brakes done on my 2015 s4. Indy shop. I'm certain they didn't release the EPB properly when doing the rears and that they used no scan tools or vag com.
    Now the pedal is generally firm but goes soft under hard braking for a split second before firming up again towards the floor.
    Do I have air in my lines? They did a manual bleed (no power bleeder).
    Any other ideas?
    A.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by s42014DSG View Post
    Hi all,
    Any other ideas?
    A.
    Sure sounds like air especially since you say they were bled. Hopefully they didn't do any damage to your EPB module. It can certainly be done without VAG if they know what they are doing, by using 12 volts and applying that directly to module contacts.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Nov 18 2014
    Turns out it was likely overloading or high pressure on the ABS system by the new pads. It's gone away now but not as the result of any brake bleed (Audi did the bleed of the lines and abs but the problem remained for a little while after and Audi said no air came out the lines). Day by day these HPS 5.0 pads are becoming easier to modulate, less of a strain on ABS and more effective in stopping power.
    Nov 10 2014
    Apex, NC
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 18 2014
    Lol!
    Nov 18 2014
    Scratch the above, as it's still happening. Is it the ABS freaking out/wheels locking up briefly? I have no idea but it freaks me out.
