I'm sure that this will come as a surprise to many of you, but my S4 is an absolute pig on gas. I've searched far and wide to narrow down a solution and I've had no luck. Over the past 4 months I've replaced my fuel filter, bank 1 pre-cat O2 sensor, cylinder 7 ignition coil, and cylinder 7 spark plug. (Only did the necessary maintenance given the winter months) I was getting about 175km/tank. After replacing said items, my mileage certainly increased. But it's still nothing to be proud of. Since then, I've had no fault codes and the car seems to be running just fine. Other than a random (slightly) rough idle I get now and again when the car is at operating temperature (perhaps related?) I now get 250km/tank on average. Granted, 90% of my driving is in the city. For arguments sake, I decided to do a couple of full tanks just on the highway to see how I compared. I managed to squeeze 380km/tank. I should note that all of these figures were of me driving conservatively, trying to use a little fuel as possible. Now, I knew long before buying this car that they weren't exactly fuel efficient. But, doesn't this seem a little excessive? Maybe it's just me... To the point, what sort of numbers are you able to get when driving your S4 conservatively? Any suggestions as to things I should try/check to improve my fuel efficiency? As always, any help is appreciated.
