Results 1 to 12 of 12
    Feb 26 2015
    United States
    About to be a pool college kid...
    But before I become one! .. I want to do something to my car.. I already need to change my o2 sensors and catalytic converter.. But I was thinking about changing my stock turbo also. I know this "might" be a very stupid question but is there a "upgrade" to the stock turbo without tuning or changing the ECU or should I just stick with a new Stock turbo? I am under the impression that if you change the turbo even with a new stock you need to reprogram the ECU is this correct. This is my first car with a turbo in it and in theory I know how turbo works. but when it comes to upgrading I am not sure.
    Thanks,
    Martin
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by fishstick41 View Post
    Thanks,
    Martin
    If you need any 02 sensors or a Cat, I have a few of each good used ones, feel free to PM me. Do you have emissions laws where you live? If you don't get a Tune, and get the tuner to tune out cat & 02 sensors, and go to a catless downpipe, no hassle, no codes. (IMO thing to do, as I don't have emissions where I live).
    Why upgrade turbo? Is your shot? Otherwise, Stage 1+ or Stage 2+ tuning software, will make the car like it had a big turbo upgrade. Motoza Is very reputable, and around $400 all said and done. A common upgrade is a OEM K04 turbo, if you want to go big.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Feb 26 2015
    United States
    Thanks for the reply, I live in North Carolina..
    "19A NCAC 03D .0541 EXHAUST EMISSION CONTROLS
    1. Any vehicle shall not be approved if the vehicle is subject to inspection with any of the visible emissions control devices placed thereon by the manufacturer are missing, disconnected, made inoperative or have been altered without approval of the Department of Environment, Health, and Natural Resources.
    Read more: http://www.city-data.com/forum/north-carolina/203440-nc-law-catalytic-converters-dmv-inspector.html#ixzz44ROhkO1B"
    So I have to have a cat.. I do not believe my turbo is broken. I want to change it because the guy that had the car before me did not really take care of the car. I rather change it now and not have to worry later. So if I do change the stock turbo with a new stock and get a stage 2+ I will see performance? Would I have to upgrade anything else like heads and injectors?
    Established Member Two Rings benjad's Avatar
    Sep 12 2014
    Mechanicsburg, PA 17050
    Is Motoza a flash? Would you have to go somewhere to get the Stage1+ or 2+. No change to I injectors? My car is all stock its a 2005 A4 1.8T USP
    Sent from my SM-G925P using Tapatalk
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    Use your available resources and use the search button. It will get you just about everything you are asking for if you use it to your advantage.
    Sincerely,
    Another Broke Student
    Sep 12 2014
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    before you talk more power, get the car in proper mechanical shape before upgrading your turbo. if you say the previous owner didn't take good care of the car, that is an instant red flag and components of the car should be checked.
    with that said above, all the cool college kids choose the f21l/eliminator turbos with a motoza tune. cheap, more reliable than big turbo, yet still putting down good numbers. then once the college kids graduate they go BT.
    good luck.
    Established Member Two Rings Northern_B6's Avatar
    Feb 20 2013
    CANADA
    If it ain't broke, don't fix it.
    You will need the cash for some unplanned repairs in your near future.
    Apr 07 2011
    Quote Originally Posted by Northern_B6 View Post
    This.
    Change all of the fluids in the car(oil, gearbox, rear diff, coolant(should be pink), power steering, brakes) and check the car for worn out parts(control arms, shocks/springs, vacuum lines, motor/tranny/snub mount). If you don't have receipts of the timing belt being done, put it at #1 on your to-do list. There's plenty more to check. Make sure everything is running in good shape before you get the tune or it will show up once you upgrade the tune. After the car is in good running shape, buy some upgraded injectors(ask your tuner which ones they prefer before you purchase) and get a proper tune for them. You'll be a happy camper.
    Click here
    ^^18 pages of great info on getting your car up to par.
    Jul 22 2012
    Pullman, WA
    Quote Originally Posted by jpulll View Post
    good luck.
    I am a college kid and I skipped the f21->BAT craze and went straight to 2.7t single turbo. :)
    Jun 19 2014
    Ohio
    wish I had time and money like you...for ppl on a budget what I said works.
    Dec 14 2011
    Chagrin Falls, Ohio
    Before you go to pool college make sure you know how to swim.
