Results 1 to 13 of 13
    Established Member Two Rings mkcolella's Avatar
    Jan 03 2016
    central NJ
    dumb question..heat/ac fan always on blast.
    ey guys,
    Every time I turn my car on ; warm out or freezing because jersey.. the fan is ALWAYS on 11 or 12, is there anyway to stop this? i tried messing with the a/c options in mmi and nothing seems to be relevant to solving this.
    also its not on the auto setting.
    best,
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Do you have the defrost button clicked? That will always go to Auto.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    Did it just start? If so, probably the blower motor resistor module. Do a scan for codes.
    Aug 06 2012
    Parker, CO
    Is your temp setting on Low or Hi in AUTO?
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Jan 03 2016
    central NJ
    Quote Originally Posted by jmeenach View Post
    hmm. just check and nope don't have that clicked.
    thank you though!
    Jan 03 2016
    central NJ
    Quote Originally Posted by gtg196w View Post
    its been doing it ever since i got the car in nov, so it would always start heating the car up but would never mind/notice really because it was freezing. but now i can tell.
    Jan 03 2016
    central NJ
    Quote Originally Posted by treginginco View Post
    nope i keep it at 72, i never really mess with that unless drastic temp change outside.
    Jun 26 2009
    Bremerton WA
    If you have a second key try and start the car with it. I am fairly certain the car sets the controls to how it was last set per key. My backup key was used last time I was doing VCDS work. I started the car a few months later with that key and the climate controls were again off just like when I was doing coding. Also does adjusting the fan speed manually actually change the fan speed?
    VMR 710's, APR software, Eurocode HFC
    Jan 03 2016
    central NJ
    Quote Originally Posted by van462 View Post
    okay im goingto try using my second or third key, and yes it does change the fan speed, the functions all seem to be working flawlessly.
    Thanks van!
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    so the different key changes the fan speed??
    Im annoyed by it also, is there a way to vag-com it with any key?
    Thanks
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Jun 26 2009
    Bremerton WA
    The car recognizes the key and configures the HVAC, heated seat seatings, mirrors and seat position (If all the memory modules are on your option package). It's great when you keep a key per driver.
    Jan 03 2016
    central NJ
    That was the culprit,
    thanks van!
    Mar 15 2012
    Just tried my other key, works how i want it lol. It sets the settings same as I left them. Im glad i read this post because this was on my list of things i dont like about the b8 a4. llol
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
