Results 1 to 40 of 50
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    So much for Cheap Gas!
    Whats with the 80 cent difference between premium and regular gas?
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    2.79 is nothing. I owned my E55 when gas was almost 5 dollars a gallon. 10 mpg was fun but expensive.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Quote Originally Posted by GRUMPY-S4 View Post
    Higher octane levels...cleaner burning gas, also would give better mileage
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    The oil industry needs to do whatever it can to stay afloat!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Nov 16 2015
    DFW
    Oil goes up ... Gas goes up... Oil goes down... Gas goes down but only after a plunge in oil
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Yea billion dollar profits every year is staying afloat huh lol
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Ain't that the truth. Crude prices go up over night and all of a sudden gas goes up. But that Crude increase is a month out from affecting current gas prices. But they go up anyways. And if Crude goes down it takes a month for the price affect to see the streets. lol. What logic is that lol
    Nov 16 2015
    DFW
    Quote Originally Posted by chaos2984 View Post
    Exactly!!!
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    This is a specific issue of top tier brands overcharging.
    We discussed the outrageous top tier premium pricing a while back and it hasn't gotten better. A BP dealer told me the dealers are overpricing because it's such a niche' market. Top tier premium should be 15% more than regular in normal markets. Your example is 40% higher and I've seen worse than that.
    Find a good dealer that is not overcharging and give them your business. Or, buy the inferior premium and put in some gas additive. Or split the 93 top tier premium with regular in 2 transactions. These guys shouldn't get away with this.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I'm seeing this a lot now. A $0.40 surcharge for premium versus regular used to be the max I'd see.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Cost-Co FTW
    Nov 16 2015
    DFW
    This is why I am running E85 full now. Huge savings
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Same in FL, big difference in gas price between 87-93, and our magical E85 gas is below $2/gal (IIRC $1.59 the last time I filled).
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    You should just start trading the crack spread if it is that easy.
    Nov 23 2014
    North Carolina
    its due to the lower gas prices. the lower the gas price for regular the larger the spread to premium. when gas prices go up the difference goes down. I remember reading an article about it over the summer when the gas in my area was 4+ a gallon the premium was only 15c difference. That's just how it goes. I still look it as savings from when it was 3/gal
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jan 14 2009
    pasadena md
    Quote Originally Posted by torinalth View Post
    Its just flat out price gouging. the overhead cost is X profit is Y and the only cost that moves is the cost of the oil Z. So when oil moves the prices should all move in unison not exponentially. I get a few cents here and there for whatever. But 50-80c difference when oil is low vs like 10-15 when oil is high doesn't make much sense. Its gas logics that no one will understand.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    It was nice while it lasted $26.00 to fill the Audi was the lowest point and E85 is the same price as 89 Octane here in MD.. So no savings there just couple cents..
    Established Member Two Rings BOO$TedS4's Avatar
    Oct 06 2015
    96 jeep Cherokee sport, 95 Mitsubishi Eclipse GSX
    Williston ND
    It's either 85 or 90 cents more here to. It was just about 5 bucks last summer then went down to 1.89 now it's 2.69. And that's for 91 not 93.... So dumb. Does anyone have experience running e85 in their b5 s4?
    B5S4
    Oct 06 2015
    Williston ND
    What kit did you get to run e85?
    B5S4
    Nov 16 2015
    DFW
    Im running EPL softy, an AutoTech HPFP upgrade and a Zeitronix ECA-2 along with my P3 Gauge.
    Veteran Member Four Rings TMurt's Avatar
    Feb 01 2011
    Indianapolis, IN
    Another reason for the widening price gap is the increase in domestic/North American shale oil. For whatever reason, crude produced from shale is richer in low octane components and easier to turn into regular unleaded. Meanwhile, foreign produced oil is more easily turned into higher octane fuel. I don't know the science behind all of this, but basically as North American production increased, regular unleaded dropped in price, but premium didn't follow suit at quickly.
    With that being said, I still consider anything over 50 cents above unleaded to be considered gouging a bit. Definitely watch out if you fill up at stations that only advertise the regular unleaded price on their signs. Pulled in to one place only to see premium at $2.80/gallon when regular was only $2.00
    Jan 14 2009
    pasadena md
    I hit up shell on Tuesdays when Premium is 20c off
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Is that all shells nation wide?
    Around here (everywhere else too I assume) e85 follows the gasoline pricing trend. It's always ~30% cheaper than 91, but when 91 goes up, so does corn.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jan 10 2007
    VA
    Price gouging is an overly simplistic, and incorrect, reason.
    Oct 06 2015
    Williston ND
    Thanks
    B5S4
    Mar 10 2015
    New England
    You do not understand how the oil/gas industry works, so do not try to explain it. Please.
    Do some research on upstream versus downstream. Believe it, or not, extracting the raw material from the ground and then pumping a refined product into your car is a bit more complicated than your X, Y, and Z...
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Yea its always been a $0.10 increment in fuel types 199, 209, 219.. Not sure why all of a sudden that most chains are marking up the premium fuel now.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Quote Originally Posted by BlownOne View Post
    Wondering that also.. I'll have to keep an eye on that~
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Not any in NW CT and we have a lot of them here. It's odd, there are no Shell stations in upstate NY at all, so I fill up over border in MA on my way upstate every Friday, it's .20 cheaper than CT.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Aug 11 2015
    In our area, I'm seeing the wide premium pricing spread for top tier gasoline brands only. The other brands like Sunoco, Wawa, Giant etc do not have such wide spreads. Since it's only a few cents more per gallon to make "top tier" gasoline, I can only describe this as opportunistic pricing. I wonder what the wholesale prices actually are for each grade and if the dealers are the ones taking advantage.
    Jul 21 2004
    South Florida
    At almost every fuel station around where I live there is a roughly 90 cent difference from 87 to 93 octane ...BUT when I am near my work it is a bit more ghetto and the Chevron there only has a 40 cent difference between 87 and 93 (it competes with a Racetrack station next to it). Yes, it is 50 cents per gallon cheaper. I just noticed it when I was forced to stop there. Its very interesting seeing the price differences in different neighborhoods around here.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    *Buys a 60,000 luxury sports sedan* *Complains about 2.79 a gallon for gas*
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by shadycrew31 View Post
    LOL
    - - - Updated - - -
    That's still less than what I pay, so..
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    It seems to me that when oil goes down, gas prices go down but there is a significant lag. When oil prices rise, gas prices rise immediately. And the bastards in the Oil industry know there is nothing we will or can do about it. Gas is a drug and we are addicted. We will pay whatever they decide to charge.
    Nov 23 2014
    North Carolina
    Quote Originally Posted by Dr GP View Post
    tesla has a fix for that.
    2019 X3 M40i - Sold
    Aug 11 2015
    Some of us bought used and paid 30-40K. In any event, I don't like throwing away money whether I can afford it or not.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    That comes at a premium and limited in terms of distance. Personally, I dislike Tesla cars, I don't care that they are faster. I'm a fossil and sooner or later we're all going to become a fossil
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Nov 16 2015
    DFW
    Just bringing up the premium scam...
    Im running full E85 and love the extra power at 40% less cost!
    Veteran Member Three Rings Bikel's Avatar
    Jun 19 2013
    No sympathy here... Premium is once again back above $3/gal! and we can only get 91oct in SoCal!!
    2010 S4 | Prestige | Ibis White | DSG w SD | ADAC Grille Badge
    Jan 26 2012
    Buick 1987 t-type turbo, Ram 2014 5.7 Hemi
    Northern New Jersey
    What kind of mileage do you get with E85?
    2012 S4 6MT Ice Silver, MMI Nav, B&O Sound, Advanced Key, Rear Sensors, Carbon Inlays, 35% tint
