    May 25 2015
    SE PA
    Tire Balance Question
    Recently put new Continental DWS (245/40 18) on my '05 Audi A6. The tire shop said my wheels/tires didn't need balanced and showed me some mark on the rim that denotes balancing not needed. As you may guess, I have a vibration. So did he tell me a story?
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Quote Originally Posted by Hivolts View Post
    Someone correct me if I'm wrong, but that guy's an idiot and they need to be balanced. I was under the impression that everything affects a tires balance. Let's say that you tires were balanced. The second you pull away from the tire shop they begin to come unbalanced. They will wear through normal driving and cornering, hitting potholes, etc. That's why they should be re-balanced when you rotate and/or @ regular intervals.
    Am I crazy?
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Balancing is always needed!!
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Jul 17 2011
    Sin City, USA
    ALWAYS balance a tire when installing new or when swapping from wheel to wheel. Even rebalance occasionally throughout the life of the tire for best performance and comfort.
    Modern tires are marked to indicate the heaviest spot (yellow dot on the sidewall) and this should be mounted opposite the valve stem to MINIMIZE the amount of weight needed to balance the tire but does not eliminate the need to balance completely.
    So yes, the guy at the tire shop is an idiot.
    Whenever getting your tires balanced go to a shop the offers "Road Force Balancing". My .02
    '09 C6.5 A6
    May 25 2015
    SE PA
    Thanks guys. Just wanted to make sure I wasn't the idiot. I'll be visiting him tomorrow for sure. My wheels require the stick on weights I think as there is no lip and I'm guessing he doesn't do those. So much for saving on my mounting and balancing price. The regular tire shop I went to was down because their air compressor was broken so this was one of those "used tire" places on my way back to work.
