Results 1 to 32 of 32
    Established Member Two Rings N'syncro's Avatar
    Feb 04 2010
    SOLD
    EDIT: SOLD!
    14.5" / 370mm Alcon / Stasis Front Big Brake Kit! B5 S4 / RS4, C5 A6, C5 Allroad
    One of the biggest and best BBK ever created for Audi's! It's no longer offered, so grab up this offer while you can! Original retail price of $3900! Will 100% fit 2.7T allroad's, and based on the info that I just got from JHM over the phone, it should also fit:
    2000-2002 B5 S4's & RS4's
    2000-2004 C5 A6 2.7T's
    2000-2005 C5 Allroad 2.7T's
    2005 C5 Allroad 4.2L V8
    I cannot guarantee it'll fit the B5's and A6's but I'm sure someone more knowledgeable than me can confirm that in addition to the confirmation I got from JHM that all the front ends of these cars are the same. They sell one single kit for all these cars, so I don't see why this Stasis kit would be any different.
    Kit includes:
    -Alcon 6 piston Monobloc calipers that provide extreme stiffness thanks to the one piece cast design and cast in stiffening bridge. FULLY REBUILT 0 miles ago!
    - 370mm (14.56") x 32mm thick Alcon rotors that feature excellent metallurgy and airflow design, fitted with Stasis' floating system to all aluminum hats to eliminate any possibility of warping as well as provide a lightweight overall system.
    -Stasis floating reusable aluminum hats with reusable hardware ( I upgraded a few years ago)
    - Stasis all aluminum mounting brackets
    -Brand new in the box Hawk HPS pads ($200 value) - 0 miles
    - Goodridge coated stainless steel braided lines
    -All mounting hardware
    Kit benefits:
    -This kit WILL fit under some 18" wheels!!! I run 18" Audi S8 Avus II's in the winter and they fit (just barely) The pictures shown with the black Oz's are 19"
    -This is essentially an Indy car front brake setup. Obviously the Indy cars are going to use a lot more exotic materials, but the design is the same
    -Offers the ultimate in stopping ability, excellent pedal feel and modulation ability and extremely long service life!
    -No more fade - Higher heat absorption and dispersion for shorter stops, turn after turn.
    -No warping - Specially designed two-piece floating rotors for quiet, warp-free performance.
    -Quicker reaction time - Short consistent pedal travel can save your life in a panic situation.
    -Improved pedal feel - Firm confidence-inspiring brake pedal due to ultra-stiff calipers, differential piston sizing and stainless steel braided lines.
    -Less weight - Enables shorter stops, quicker acceleration, improved steering feel and handling.
    -Lower long-term maintenance costs - Cutting-edge design in a durable, low-cost system.
    -Compatibility and ease of installation - Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power
    Notes:
    1) As you can see in the picture, the rubber coating on the brake lines has worn off in a couple of places. The actual SS brake line is perfectly fine though!
    2) The bolts that connect the Alcon calipers to the Stasis mounting brackets are stuck in there damn good! I don't know what kind of loctite the P.O. used when originally mounting these, but I can't get them off. You don't need to, but I'm just being 100% transparent (no surprises)
    3)The rotor rings are nearly worn out. Could you use them for a little while probably, but I wouldn't recommend it. Alconkits.com sells 2 different options for $1079 to $1299 per pair.
    I just sent the calipers for a full spared-no-expense rebuild at HRPWorld, who was recommended by Alcon. These calipers are now essentially brand new again. Everything was replaced & they are good for another 100k miles. The calipers sell for $2000usd, I just spent $1180 on rebuilding them.
    So $2100usd shipped for what I have, plus $1079 for rotor rings, & you've got an absolutely brand new, completely BADASS and HUGE BBK that's going to last you many many miles for $3179. The cost of this kit is high up front, but it lasts far longer than other cheaper BBK's, so in the long run this kit ends up costing less to run than many of the much smaller 350mm bbk's on the market.
    List Date: 3/30/2016
    For more info, click here to view the original listing: 14.5" / 370mm Alcon / Stasis Front Big Brake Kit! B5 S4 / RS4, C5 A6, C5 Allroad
    This item is no longer available.
    Feb 04 2010
    Bump
    Feb 04 2010
    TTT. I don't need these sold, but I want them sold lol
    Feb 04 2010
    Bump. No one wants a gigantic BBK?
    May 22 2016
    2006 electric blue evo 9, 2jz e46, rwd b5 a4, b7 a4 sline titanium airlift 3p
    Roseville
    Want so much ahaaaaa
    Sent from my SM-N910V using Tapatalk
    Senior Member Two Rings milehighkid24's Avatar
    Oct 25 2013
    Nardo Grey B8.5 S4, Casablanca White B5 S4
    Scottsdale, AZ
    Do you still have them?
    Feb 04 2010
    Yes I do. The "No longer available" refers to the fact that you can no longer buy the kit new.
    Feb 04 2010
    Bump!
    Feb 04 2010
    TTT
    Feb 04 2010
    Bump. Still have this kit. Perfect for a winter build.
    Feb 04 2010
    TTT
    Feb 04 2010
    Bump
    Feb 04 2010
    Bump. Not sure why this is saying it's no longer available, because it is definitely STILL FOR SALE!
    Feb 04 2010
    Bump. Still for sale!
    Feb 04 2010
    TTT
    Feb 04 2010
    Bump. Still for sale.
    Feb 04 2010
    TTT
    Feb 04 2010
    Feb 04 2010
    Bump. Just moved into my new house and remembered I still have these and I do not need them!!
    Feb 04 2010
    Still for sale
    Feb 04 2010
    TTT
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    free bump for a pretty allroad!
    Junior Member One Ring
    Oct 04 2017
    Australia
    Do you still have these?
    Feb 04 2010
    Quote Originally Posted by plaz View Post
    Yes I do
    May 22 2016
    Roseville
    For a bbk for a b5 this is overkill. And 2k used needing rings.... buy a brsnd new 18z kit rebuilt. Cost u 2k new
    Sent from my SM-N950U using Tapatalk
    Feb 04 2010
    Do you have first hand experience with either kit or are you just a keyboard warrior?
    I have an 18z kit on my front right now and there's no comparison. Bought it while the Alcon's were out to rebuild, but I don't drive my car enough to justify or bother switching it back to the Alcon set up.
    Thanks for the bump though.
    Senior Member Two Rings Stage_3's Avatar
    Jun 20 2019
    Denver
    Quote Originally Posted by N'syncro View Post
    I second this. My Alcon/Giro setup blows any 18z kit out of the water. Night and day difference from the 18z brembo kit on my old URS6 avant.
    Free bump :)
    Current Stable:
    B5 S4 Avant - far too much to list
    Feb 04 2010
    Thanks Stage_3! It's also nice when you've got stage 3 goodies on your car
    Senior Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    Quote Originally Posted by Stage_3 View Post
    Free bump :)
    I third that, terrible off the shelf selection of pads for 17Z/18z’s. Have custom to order pads for HPDE’s.
    2001.5 S4 Imola
    Oct 04 2017
    Australia
    PM Sent
    Feb 04 2010
    Bump. Still have this sitting in my basement.
    Apr 15 2004
    Santa Barbara
    Please email me at [email protected]
