Results 1 to 3 of 3
    Active Member One Ring brad131a4's Avatar
    Oct 28 2005
    09 Jetta (DD) 11 Golf tdi (wifes) 90 Vanagon 72 fiat spider 76 fiat spider 74 Alfa spider (wifes)
    Sammamish WA
    Need info on how to remove rearview mirror.
    Of course can't find the info that I found before so asking again. Trying to remove the headliner of my 01 S8 and have everything else removed. Only thing holding me up is the rearview mirror. Don't want to destroy it but have just about gotten ready to cut it off at the stem if I can't find the proper way to remove it,
    Thank you for any help.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    2001 A8
    http://workshop-manuals.com/audi/a8_...dliner/600101/
    2002 S8
    http://workshop-manuals.com/audi/s8_...dliner/600101/
    I would suspect they are pretty similar, but I have no first hand knowledge. You will also need to use the navigation links in the left hand toolbar.
    Edit: Different year, but I believe this is on the same system. http://www.justanswer.com/audi/5mnoy...8-replace.html
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 28 2005
    Sammamish WA
    The just answer one did the trick. I couldn't find any reference to removal of the mirror on the other two. I did find out it's in group 70 in the book. They just didn't have it listed with the rest of the headliner removal diagram.
    Thank you for the info.
