Results 1 to 17 of 17
    Apr 26 2007
    GTA
    3.2L - Which oil do you guys use?
    Hey Guys,
    I had my first oil change since buying the A6 3.2L in January and after 3000 kms (about 1900 miles) I am getting the low oil light almost every week after topping up (or approx every 500-600 kms). No leaks on the floor or any check engine light and the car runs great.
    I have searched everywhere about this issue but just wanted to chime in with you guys to see what your all using and how bad the oil loss is.
    I used mobil 1 10w-30 synthetic.
    I live up in Toronto, Canada so we get cold winters and hot summers.
    I am considering trying Castrol Syntec 5W-30 for the next change.
    What are your thoughts?
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    My dealership uses the Castrol 5w-30 syntech for all my oil changed since I purchased mine at 84k now has 164k miles. Granted I've had to fix a leaky seal or 2 but if you aren't seeing any leaks you might have a faulty sensor.
    Sent from my VS985 4G using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Apr 26 2007
    GTA
    I think the sensor is ok as when it does go off, the oil level is on the low side ...
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by hiru View Post
    The sensor should only go off when the oil hits the minimum level as indicated on the dipstick. Adding a quart brings it up to the top mark. So you are adding a quart every 500-600 km (350-375 miles)? This consumption seems very excessive to me and would be an indication of a leak somewhere. As our cars have a belly pan that can catch oil, not seeing a puddle is not necessary an indication that there is no leak. Have you pulled the belly pan off and inspected the motor from the underside?
    As for oil, my indie shop has always changed my oil with 10w-40 full synthetic Mobile 1; I don't have the cold temps but I have HEAT!!
    '09 C6.5 A6
    Apr 26 2007
    GTA
    Have not taken the belly pan out, will trying checking that to see if theres any leaks
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    I'd think the leak would have to be quite massive if you are losing that much. You would still notice is without even having to remove the belly pan, it would just leak off of it onto the driveway/garage floor. Just from having leaky valve and timing chain covers, I saw oil on the floor without removing that cover. My guess is that it's consuming the oil more than likely - we've seen some 3.2's report large consumption amounts. What year is your vehicle and how many miles does it have?
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Any 502.00 rated oil will be good for you. For your particular car, it could depend on climate as to what a better weight oil would be. I personally use Castrol Edge Professional 0w-40 in my 3.0T (in California), but I was also using that on my 3.2L when I had it. I've thought about switching to Mobil 1 as I always had good results in other cars. But lately, I buy (3) 5-Qt jugs from Amazon for $23 a jug. The price fluctuates up and down, but that's why I buy 3 of them when the price gets good. I've seen this oil cost $50 for a jug (likely what you'd pay at the stealership).
    I would use M1 and Castrol interchangeably since their flow numbers are very close to each other. For me, I found a good price point on Castrol and it's the one recommended by Audi, so unless I'm getting a stellar deal on the M1 or the Castrol is not available, I'm sticking with the Castrol. If I'm not mistaken, It's the same formula as the 'German Castrol' that oil enthusiast folks were seeking out 8-10 years ago for import.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Veteran Member Four Rings Quattrocentric's Avatar
    Oct 19 2013
    Another Audi, what else?
    Silver Spring, Md
    I swear by Liqui-Moly 5W-40. My local NAPA Auto parts stocks it for $33.91 for the 5L, but I know it is sometimes available online for less.
    ...and yeah, you have a leak. Sorry.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    i use 5-40 motul xcess and do my changes every 7000km i would only need to top up once.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Established Member Two Rings Euro_head's Avatar
    Mar 11 2014
    96 A4 B5(sold), 98 A4 B5(sold), 03 A4 B6(sold), 01 A4 B5(rip)
    Reading, PA
    While we are on the oil leaks do you guys know the common leaks for the 3.2 . Mine started a very small leak on the rear of the Engine but it's very small and also one that drips here and there on the front of the engine on the left side (passenger)
    Apr 26 2007
    GTA
    no obvious leaks, its a 2006 with 97000kms (~60000miles), cheers for the input
    Feb 19 2013
    Quote Originally Posted by Euro_head View Post
    VC, Cam plugs and seals, and tensioner cover gaskets. The ones you are talking about are likely the cam plugs
    Dead:
    Mar 11 2014
    Reading, PA
    I'm about to see if fcp has all of that and just replace it all at once.
    May 17 2009
    Idaho
    Also, I would throw in main seal as well. Maybe not as common, but my previous C6 developed one @ 110k miles.
    Current:
    2002 1.8t A4 Sedan
    Mar 11 2014
    Reading, PA
    The dealer actually replaced the rear main when I bought the car . Should I replace the bolts to the valve covers ?
    Feb 19 2013
    Not unless you feel like spending extra money. They are plastic covers that don't have any real forces playing on them. I would not as these bolts should never reach anywhere near their yield in operation.
    Dead:
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    I would change your PCV valve if you aren't noticing a large leak. There were a couple years where VW/Audi used PCV's that are prone to fail.
    My 4.2 was using a quart of oil every 1000 miles and then i changed my PCV and now I don't have to add any between oil changes (Every 5k miles)
