    Veteran Member Three Rings Adplaya's Avatar
    Apr 25 2015
    TEXAS
    Question Running wires from glove box to center console
    So I'm trying to run some wires from my glove box to the center console, and keep them as concealed as possible. Whats the simplest and cleanest way to do this?
    I could do some tucking, but eventually the wires would come out near the arm rest and feed into the center console, which I don't know if that's the way I want to go.
    Basically I don't want wires feeding into the center console\armrest, I want to route them so they are in the center console/armrest. Similar to this http://forums.vwvortex.com/showthrea...-MK6-Jetta-SEL
    Mythos Black on Black SQ5
    H&R springs - CF Mirrors - Eurocode Transmission Mount - Black Diamond AWE Touring Exhaust - Hardwired V1 (for the haters) - LaminX
    - 15/20 Spulen Spacers - Thinkware F750 2CH DashCam - 034 Rear Sway Bar and End Links
    Senior Member Two Rings DanMontgomery's Avatar
    Jun 07 2014
    Q5, S5, A4 and ALLROAD
    Clarksville, TN
    Sir,
    Can you post a few pictures of where exactly your having the issue or something like that?
    Maybe the plug as well?
    V/r
    Dan
    2013 Audi A4 (Hanz) Prem + 2.0T Quattro Monsson Gray
    2013 Audi ALLROAD (Elsa) Prem + 2.0T Quattro Monsoon Gray
    2013 Audi S5 (Max) Prem + 3.0T Monsoon Gray
    2014 Audi Q5 (Ann) Prem + 3.0 TDI Scuba Blue
    2015 Audi Q5 (Franz) Prem + S-Line 3.0 TDI Daytona Grey Pearl
    Apr 25 2015
    TEXAS
    Quote Originally Posted by DanMontgomery View Post
    Sir,
    V/r
    Dan
    Attached a picture of the traditional way to route the wires (red line), but definitely it's not clean. I'll be running an HDMI cable and a MicroUSB cable, so nothing too thick.
    Junior Member Two Rings
    Sep 03 2015
    Dallas, TX
    There's some small holes on the top right, inside the glove box. It exits behind the fuses. I ran my dash cam battery backup wires through there, up the A piller, to the read view mirror.
    The only problem is the holes aren't big enough for HDMI or Micro USB cables. I had to cut my wires, fish it through then splice them back.
    Thats the only holes I could find in the glove box, it's sealed pretty well.
    Maybe you could pop off the cover for the ipod connection?
    Apr 25 2015
    TEXAS
    Quote Originally Posted by sbc580 View Post
    I found the solution! http://www.audiworld.com/forums/a4-b...ired*-2864770/
    Gonna run it along the side of the gearbox instead of under the seat, but it's totally do able. Already took everything apart and it's a 100% go when all my wires come in. Cheers!
