Results 1 to 8 of 8
    Sep 24 2013
    Chicago, IL
    first time getting brakes done question
    i will be getting S4 calipers upgraded on the fronts and keeping the rears stock for now.
    has anyone done brakes recently and how much labor times does this take?
    thanks in advance.
    Established Member Two Rings theSaint024's Avatar
    Jul 16 2014
    SF CA
    Quote Originally Posted by dapeople View Post
    thanks in advance.
    Typical brake pads and rotors will take a pro no more than a half hour per corner. I haven't upgraded calipers, but I can't imagine it's much more time, if any, swapping those out.
    2013 allroad - ibis white P+ - The answer is... "it's an allroad bro."
    Sep 24 2013
    Chicago, IL
    dealer wants to charge me 10.5 hrs for this, i don't think this is realistic?
    Jul 16 2014
    SF CA
    I can't imagine it taking that long unless the S4 calipers don't fit out of the box and major modification is needed. I would get another quote, I think that's gouging. Someone else who has swapped the calipers might be able to chime in and inform if they don't fit out of the box.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    That's ridiculous, the longest process with changing calipers is you have to bleed the brakes in the front. Don't go to the dealer find an Indy shop if you can't or don't want to do it yourself with a friend.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    For what it's worth, my local performance shop quoted me $150 + fluid for the exact same install.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    10.5 hours is insane. Find a good local shop. Or like it was suggested, it is def something that you can do yourself if you have the tools/means.
    The S4 calipers, with carriers are bolt on..when I swapped my fronts for the Q5s, I don't remember it taking more then 2 hours.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Sep 24 2013
    Chicago, IL
    that's what i though
    this is what they said:
    We typically charge about 10 hrs of labor to do that, witch is roughly $1,614.25 an that’s just labor no parts for the rear brakes.
    For you ill charge you 8.5 hrs an ill discount the labor pricing for the front an rear brakes
    Breakdown
    2 hr for the front $300.00 for you $266.00 pads an rotors
    1 hr for the brake bleed $139.95
    1 hr for each caliper an the pins includes 2hrs $300.00
    Half an hour for both the steel brake lines $150.00
    Labor for the front brakes, pads, rotors, brake bleed, calipers an pins, brake lines total $855.95
    Labor for the rear brakes is 2.5 hrs again I have it discounted for you from $375.00 to $333.00 that extra half hr is because the car has electronic parking brake in the rear.
    Pads $113.00
    Rotors $140.00 x 2
    Total $726.00 plus tax
    Grand total $1,581.95 plus tax for only the rear brakes pads an rotors, no tax on labor..
    - - - Updated - - -
    thanks guys for the info.
