View Poll Results: Which V8 S5 tune do YOU have?
Voters
9. You may not vote on this poll
  • APR
    1 11.11%
  • JHM
    6 66.67%
  • Neither, and I don't plan on getting one.
    2 22.22%
Results 1 to 10 of 10
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    V8 S5 Going in for a Flash Tune. Experience with APR and JHM?
    The time has come to tune my 4.2L V8 S5.
    It seems that I have two options for the V8: APR or JHM. I've done some research and read as many reviews as I could find. I cant seem to find many APR reviews, but it sounds like the JHM tune makes a "night and day" difference - so that's what I'm leaning toward right now.
    This isn't a discussion about dyno numbers or quarter mile times. I want to learn a little more about the user's experience before I decide to finally pull the trigger.
    For those of you with either tune, I would greatly appreciate your comments on:
    Reliability - Has anything gone wrong after your tune? I have a stock clutch and would ideally like to preserve it (I dont plan on launching my car often and I go to the drag strip maybe once per year).
    Daily driving experience - My car is my daily driver - I want to be sure that it will still be practical for everyday situations (stop and go traffic, bad weather, snow, etc). I heard that the JHM tune makes the throttle response much more sensitive - especially in lower gears. Is this true? If so, is it easy to adjust to?
    Tuner support/ customer service - Is the tuning company easy to contact and willing to help if you have any questions or concerns?
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    From what I understand, there isn't much to be gained from trying to tune a NA engine. APR is only reporting 18HP/16 Ft-lbs over stock. I'm not sure if that's worth it to you, but that could be why there aren't a lot of user reviews since many chose not to bother.
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    For most, its not the gobbs of power they are looking for. Its a smoother throttle response and better top end. On my 4.2FSI (VW Touareg), I had a file loaded from Evolution Motorsports (local Porsche tuner). Was it like a Stage 1 file on a 1.8T, no. But did it help, yes. The Touareg wants to just keep pulling in the upper RPMs. Where as before, it just kinda cruised through the 4-7k range.
    If I had my choices, I would choose JHM, just because the amount of time they spend getting the most out of their NA motors. They just haven't had anyone with a local 4.2FSI Touareg step up, so they could pull their ECU and start tweaking.
    Sep 06 2014
    Rochester, NY
    Pulled the trigger on the APR tune. Explanation why, and more details in my "update, upgrade, & photo" thread.
    IG: @SLU_S5
    Established Member Two Rings TTALMS's Avatar
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    Quote Originally Posted by SLU_S5 View Post
    I actually had the APR file first since my first Audi was a 1.8T and APR does wonders with turbo engines. But then I switched to JHM and haven't looked back. They seem to focus a lot of attention on getting every bit of power out of the 4.2. I personally felt the JHM tune made my car more responsive and smoother versus the APR. But as others have said, not much from a power gain for either one. My local shop supports both.
    JHM linkage w/ USP SS line : test pipes : pulley : intake spacers : tune : 2-pc rotors Ecode shifter : sways : end links : AK : Sport UCAs w/H&R coils & CR-15 AWE Non-res downpipes w/ GMG exhaust : intake tube w/ APR CF intake 034 mounts & inserts Style VFF103s : DEVAL : BFI knob/boot : custom s-wheel : CF inlays
    Senior Member Two Rings street sleeper's Avatar
    Jan 04 2015
    Pittsburgh, PA
    Some newbie questions...
    Does JHM even make an ECU upgrade for the S5? Couldn't find one on their site.
    And what about GIAC? AWE Tuning sells it and I've had great experience with their products.
    APR $699.99 (+15hp)
    GIAC $630.00 (+18hp)
    If you drop $600-$700 for an ECU upgrade, how much is the install/tuning? Would the dealership be able to do this or would I need to go to tuning shop?
    I think of ECU upgrades like overclocking computers back in the late 90s. Sure there are some benefits, but for the little extra power you get out of it...I'm wondering if the cost and potential for something to go horribly wrong is worth it?
    2008 Audi S5 (6MT)
    Meteor Gray / Magma Red Leather / Carbon Inlays
    Euro Spec Headlights / 35% Tint / Satin Black Grille, Fogs, & Rear Valence
    AWE Track Exhaust / AWE Carbon Intake / Short Shifter / H&R Sway Bars
    H&R OE Springs / Brembo Brakes / BBS CH-R 20x10.5 / Michelin Pilot Super Sport XL 275/30ZR-20
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Quote Originally Posted by street sleeper View Post
    APR $699.99 (+15hp)
    Here's a link to JHM tune: https://jhmotorsports.com/shop/catal...2v-p-1561.html
    Install cost usually ranges from Free to 1/2 hour of labor. I think there are some rare cases of dealership doing tunes (maybe that's an older thing) but you'd most likely need to go to an authorized tuner.
    Tunes value on NA motors / your V8s are subjective, you're looking at mostly powerband optimizations rather than peak numbers. Heck most of these tunes advertise increased MPG even with their increased power. For forced induction it's more extreme. For example on the 3.0T motor APR advertises +111 peak HP and +134 max HP on their stage 1 93 octane tune. It was a no brainer for me.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by LordMagnet View Post
    This is probably a dumb question, but why exactly is that?
    Why does the V6 get +111hp from an ECU upgrade, but the V8 only gets +20hp max if it's lucky?
    2008 Audi S5 (6MT)
    Sep 06 2014
    Rochester, NY
    I have a very basic understanding of how this works so anyone else is free to chime in here:
    On a very basic level, forced induction cars have a much greater tuning potential. Though the 3.0 in the B8.5s have a smaller displacement, the supercharger will force more air into the engine to be combined with fuel at a faster and more explosive rate which can yield more power. Decreasing the size of a supercharger pulley and adding an intake can make it easier for air to become available and forced to the engine at a faster rate. The tune can help improve fuel flow and can help to ensure an ideal fuel to air mixture which will also cause better power over stock.
    With a naturally aspirated engine like the V8s, we're missing the ability of a supercharger to force more air into the engine. Fuel needs to be combined with air at a certain mixture to burn optimally. With less air density in the engine, less fuel could be added for an optimal explosion - potentially yelling less power than its forced induction counterpart.
    IG: @SLU_S5
    Jul 20 2015
    Connecticut
    The magic of forced induction. Audi over-engineered the motor, and then marketing came in and told them how much power to limit it to. I believe they achieve this by bleeding the boost. Then the tuners fix the limiters.
