Results 1 to 29 of 29
    Oct 23 2015
    Australia
    Why should I spend more on a JHM High flow Cat over 034's popular offering ?
    Convince me to spend another ~ $A120 on a JHM high flow cat over an 034.
    Factors are : I have included in 034's price their oxygen spacer,JHM claims it isn't needed.
    034's price includes the gasket/fitting kit, with JHM's its an extra and has been taken into account.
    JHM charges freight,I can buy an 034 shipped free (in USA),also included in the comparison.
    I think I can see why one may be better than the other-but is it worth the extra spend -I've bought rims,coilovers and a heap of maintenance gear today from the USA ,now that's fun but it all adds up
    Unbiased opinions please,NO Company reps will be listened to,lol !
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Oct 24 2015
    Perth, WA
    I haven't used both, but my 034 one really opens it up and makes a nice grumble in the lower end. I def noticed better power with the butt-dyno.
    My respray thread
    Oct 23 2015
    Australia
    Quote Originally Posted by Okedokey View Post
    Yep,I was aware you had that ,I still need convincing but after my big spend day,I could save some bucks with the 034 ! I still want to get down to see your car and listen to the BSR,maybe soon seeing the Easter madness is over...
    Do you have a spacer or is the rear lambda straight in ?
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Why do you need to be convinced? Buy whatever you want and can afford
    Case closed
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 23 2015
    Australia
    Quote Originally Posted by Schweini View Post
    Case closed
    So you say,but I am a guy who wants the bestest for the leastest ! Lol,Are you familiar with the ins and outs of the thread topic, if so I'd like to hear your meaningful contribution,cheers
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    JHMs hfc offers a .5" inlet whereas the 034 is only 3". That's in your cars best interest. Since thats what you're after, get the JHM
    If you want the "bestest for leasest", then get the 034
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 23 2015
    Australia
    I know what you meant ,3.5" and yes thats what I was figuring,I also like the way that the JHM cat body is welded in as far downstream as possible away from the heat.That's a biggy,the OEM is madly close to the turbo o/let.My exhaust guy,not having seen many Audis commented on this.
    Others may have picked up other benefits for one or the other.Longevity for example,but that would take time to prove,I'm guessing the shitiest cat matrix would last 10's of thousands of miles.
    I'm not after long life though.
    Edit: Geez are you in Ontario,its 0400,go to bed,even Neil Young would'have !
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    JHMs is better if you're opening your exhaust with their downpipe and B6/B7 exhaust to give you a full 2.5" exhaust.
    If not 034 is probably the way to go
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 24 2015
    Perth, WA
    The 034 is 3" throughout
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Ringsby4 View Post
    I work night shifts, lol
    At anyrate... i have the 034 and its fine. Either or are from reputable companies and both will get the job done
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings Rabbit's Avatar
    Aug 17 2009
    Unicorn shit
    PNW
    I too have the 034 HFC and enjoy it.
    Oct 23 2015
    Australia
    Quote Originally Posted by shahk62 View Post
    I really like the look of the JHM dp but you could buy the rear end of my car for the price and then you need the S4 dual system to complete,no I'll just use a 2.5"custom pipe to my resonator which from reports I may even remove.
    my wife does too,weird world that twilight life ! I think 034's the way to go and Europa has them in stock,I just cant see the $$'s giving me so much more....
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    Take into count your local laws as well.
    In VA the JHM's product wouldn't pass in most instances because the O2 is not in the main stream and is built in offset.
    I would have to go for 034 in this respect as the base product has all 02 sensors mounted direct.
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    This is an important fact that shouldn't be overlooked. with the turbo car, you want the least restriction as possible. The same is said for the cat placement; the further away from the turbo, the better.
    The JHM hfc also has the integrated J-bung so even on a stock tune, you're guaranteed to not have a CEL. For the small price delta, I would say the JHM is worth it.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I've had the 034 on for about 6 years... and about 100k miles. The construction is top notch to say the least.
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    I think both are great quality products, I run a full JHM exhaust and it opened up, however I'm one to squeeze out every last bit of power from my car as possible and have big turbo plans I'm the future. So with that said that half inch ment the world to me because I wanted the best flow possible. Eventually I'm even going to be testing different set ups to increase my intake g/s to really maximize my setup. Either one will work is my point and you'll feel it in your pants. I consider JHM to be more than worth it, but can also see the benefits of probably having very very close to the same power with going with an 034 set up.
    Tldr: go with 034 unless youre planning on going BT.
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    I had a fabrication error on my 034 HFC (back when I had one). Luckily, I am kinda local to them and was able to drive over and show them as they didn't believe me until they saw it. The turbo flange was welded backwards. Once they saw it, they grabbed a new one and swapped it for me, no further questions asked. I am the only one that I have heard of having the fabrication error so don't think it is a common thing at all. The sounds was great with the Stasis exhaust, much better over test pipe which starts to get somewhat tinny and drone.
    I have a JHM test pipe now and I will say it is very quality made product with exact fabrication and the down pipe of my Stasis exhaust sits better (less low) and scraps way less) than it did with the 034 HFC. I am not sure how to describe it better but the down pipe hung lower and was the lowest point of the underbody with the 034 HFC but with the JMH TP, it sits tucked up and protected better.
    If performance and best fitment is your goal and willing to spend the extra money, go JHM
    If you want tried and true great sound and save some money, you can't really go wrong with the 034 HFC
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    First 034 hfc i received was a fabrication defect where the flange was welded backwards
    Received a second one.
    I found it loud and way too rapsy.
    Went back to stock oem cat converter so happy lol
    I might get the k04 from apr so that ill bolt on the stock cat
    Oct 23 2015
    Australia
    Quote Originally Posted by Avant4me View Post
    Its illegal to mess with the emissions parts over here but having said that we don't have annual emissions testing.
    Quote Originally Posted by ktish View Post
    Good point,this is a biggy about the J bung,ppl have had trouble with high flow cats of all varieties even with spacers etc -Has anyone had a MIL or code with the JHM ?
    Aug 17 2009
    Unicorn shit
    PNW
    Quote Originally Posted by rongeur View Post
    How low are you?!?
    Oct 24 2015
    Perth, WA
    Ringsby4, check here, it should be fine http://www.rms.nsw.gov.au/documents/...ifications.pdf
    My respray thread
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Thanks for the support guys!
    Discover Your Vehicle's True Potential with JHMotorsports | Visit Us at JHMotorsports.com ๐Ÿš€๐Ÿ
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by Rabbit View Post
    How low are you?!?
    Not very low at all by forum standards. 24.75 FTG all around.
    However, I have to go in and out of SF and my office parking lot has some ridiculous speed bumps.
    Build Thread
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by pat_do View Post
    There mist have been a run like that then.
    Build Thread
    Aug 17 2009
    Unicorn shit
    PNW
    Oh yeah, speed bumps are the devil.
    Sep 27 2008
    Phoenix
    Step it up a notch. Purchase the RAI HFC, it has a 4" inlet so it's the least restrictive HFC you can purchase for our platform.
    http://www.raimotorsport.com/R-A-I-M...-b7-a4-hfc.htm
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by wootwoot View Post
    I think the turbo outlet is only 3.15" though. So really, anything over that is overkill and unnecessary.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 31 2011
    Lathrop
    They still use the factory Cat pipe to downpipe gasket, which means that it is still restrictive. We manufacture a special gasket to match the large ID of our HFCs and TPs.
    Oct 24 2015
    Perth, WA
    Yeah anything over the weakest link in terms of diameter will be pretty pointless.
    My respray thread
    ยฉ 2001-2025 Audizine, Audizine.com, and Driverzines.com
