2000 Santorin B5 S4 Stage 3
Ok so the time has come to sell the S4, looking to buy a house. It's a 2000 with approximately 105k miles. 6 speed manual transmission. The car had one middle-aged owner before me, he bought the car new. I bought the car bone stock at 88k miles. The car just past CT emissions.
Mod list:
Oem rs4 k04 turbos with new chra
Apr intercoolers
550 cc injectors
Full autospeed turbo back exhaust, sounds mean at WOT, fairly quiet at idle.
Podi boost Gauge
Vogtland coilovers, lowered but ride height is functional.
Vmr 18x8.5 wheels with hankook ventus v12 tires, plenty of tread left. Minor curb rash on a couple of the wheels.
710N diverter valves
Samco throttle body boot
New South Bend Clutch and Single Mass flywheel, good for 550 wheel torque
I also have a Neuspeed rear swaybar I will include with the car.
Maintenance:
Timing belt/water pump etc. done around 70k
Another 7k worth of maintenence done by previous owner, I have receipts
Driver side rear wheel bearing replaced around 90k
Coolant pipes/o-rings around 100k, new coolant reservoir
Front upper control arms on both sides done at 105k miles.
Oil changed regularly
No leaks
I have the stock 17 inch wheels with Pirelli all season tires, 75% tread left.
Bad:
Bottom passenger side of bumper got cracked from a branch in the road
Minor paint imperfections
Probably needs a steering pump at some point, not a major issue currently
The car is currently tuned to 22 psi spike, tapering to 21 psi. Puts down around 400 wheel horsepower, give or take. Paint is in great shape, interior is very good condition. All of the engine work has less than 10k miles on it. Engine work, downpipes, tuning and some maintenance was done by a Dave Chang in Massachusetts.
I'm probably forgetting forgetting some stuff.
I'm not sure how to add more pictures, the file size is limited to 4.2 MB. I can send all the other pictures if interested.
12,000 with both wheels.
(860) 888-2867, text or call
List Date: 3/30/2016
For more info, click here to view the original listing: 2000 Santorin B5 S4 Stage 3
This item is no longer available.
