Results 1 to 3 of 3
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Removal of entire rear hatch B6 Avant
    Hi guys, I really purchased a "new" rear hatch due to the one currently on my Avant being all dented up. Is there a D.I.Y, Bentley guide or anything along those line to help me remove and swap it? Before you guys start spitting venom at me, I did do some research and found how to remove the rear hatch inside trim and that's it. Thanks
    Aug 26 2005
    After you remove the interior trim, and all of the wiring from the hatch lid, remove the struts. With the hatch closed, remove the hinge bolts holding the hinges to the hatch lid. Next, from the inside, release the latch and lift the hatch lid away from the body. Make sure the hatch is aligned right after installing the new hatch lid. You can download the factory service manual from Audi erwin for $32 one day access.
    https://erwin.audiusa.com/erwin/show...FD.ASTPERWUS01
    Vorsprung durch Technik
    Mar 03 2015
    Easton PA
    @diagnosticator were you born this awesome or did the german gods bless you? Thanks!
